Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: sid305 reset km
  1. #16
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Quote Originally Posted by uliasz View Post
    in abs 335399. J need reset abs or set 146000km. J repair dash and is ok, but nyo not working . xtool haven't got in list: abs laguna3 ( try in scenic but not working)
    Here it is...
    146000.rar
    Live by the rules and die by the rules...
    Thank before you die...
  2. #17
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Hi. J try both dump today , but after writing the first or second dump is 327751km in ecu
    Try this dump for ECU...
    Please report the result....
    Eprom mod.rar
  3. The Following User Says Thank You to Landetos For This Useful Post:
    uliasz (5th July, 2016)
  4. #18
    Dec 2009
    Abs working. Ecu is working too(dump: eeprom_00). Thanks
  5. The Following User Says Thank You to uliasz For This Useful Post:
    Landetos (5th July, 2016)
  6. #19
    Dec 2009
    Landetos Can you set odometer to 164tys in abs again. Sory my mistake
  7. #20
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Cool
    Odometer in ecu is 327623km. Anyone help
    SMOK Multi UHDS tool working like charm on OBD yesterday I try and work great on OBD (total km , last dpf , km from last successful dpf reg....)
  8. #21
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Simple as download the file again
    Right?
  9. #22
    Dec 2009
    I will be grateful. Nyo calculate odometer ok but in crc is problem. if you can make 164tys in abs. Thank you
  10. #23
    Dec 2009
    set 164500km but need corect crc .
  11. #24
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Load the 146 file to ABS...
    Make dash to 164500 and job done...
  12. #25
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Anyways...
    Here...
    164500.rar
  13. #26
    Jun 2010
    and one from me
    any help appreciated
    has 204.... and i need 167....
