this clear crash , erase fault codes
bolvan555 (28th November, 2016), elektrik28 (3rd September, 2017), flyins (25th February, 2016)
Pass please
Pass please
Please pass
Post here your dump, somebody help you ...
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
Renault Twingo 2011
402792b8
8201 236 030
eeprom 95160
*S3W2B24A40A*
I need crash data clear.
twingo crash.rar
I did crash data clear
I will only change 398: 00 00 1C 70 00 00 00 00
I have another problem.
My sensor was already repaired.
I guess it was badly done.
The car is good, the airbag, the tensioner, have been replaced.
The problem is always the driver and passenger tensioner DF183, DF184 configuration.
If the tensioner disconnects the problem ceases.
The first post is the memory I read at the beginning of the repair.
I need a dump with tensioners and clear.
Please help
here you go clear for you
Probably someone put on resistors on the cables
Check the parameters that are the resistance of the tensioners
elektrik28 (3rd September, 2017), thomas20 (25th March, 2017)
Thank you,
tomorrow I will check and write
After checking the sensor I have such requests
With a passenger tensioner the value of resistance is 2.2 ohm, and DF184 is the fault
Passengers side front pretensioner circuit CONFIGURATION
Without tensioner, no error. Resistance value INCORRECT VALUE
Without the tensioner, the error is gone and the light is not lit, it is all OK
The driver and passenger side react the same way
I needs a dump with tensioners
Problem solved.
Thank you all interested.
