bid178678 (26th April, 2018)
I've not cut GT15 with the latest update yet. Has it still cut the tip of the key?
Do you a contact for Condor XC after sale ?
this bitting code must be 33224311?
fytfh (28th April, 2018)
Samic Why condor mini cant decode lexus toy48 and toy40 keys?
i mostly cut lexus keys and i cant decode it by condor mini..
friend, Condor MINI usually decode/cut key as the standard thickness 3mm, if the key is single side(thickness no more than 3mm, such as 2.5mm or 2mm)
then you should add a shim(such as business card) under the key, let the key thickness more than 3mm(around 3mm).
He finally passes by and that's what we get.......
Hey samic where is m4 jaw
I got some keys I'd like to be able to cut
Thanks for quick reply..
i was able to decode toy40 and toy48 only 4-4 cuts. with 8-8 cut it still dont decode ..(have latest sw version of condor)
but if i manually put the bitting it cut the key.
Anybody decode citroen sx9 keys with condor mini?I was trying to duplicate this key but condor start the process and after 3 second stops.
Has anyone figured out a good workaround for this? The pullout 2004-2009 Prius emergency key is too short to reach the 2nd line like a TR47 blank.
Perhaps Condor can modify the software to allow you to "move" the line to position 3 or 4 from the top via software for keys like this?
I know I can cut onto a TR47 then copy with a side by side duplicator but it would be nice if my $3000 machine can do it directly.
