Page 478 of 847 FirstFirst ... 378428468473474475476477478479480481482483488528578 ... LastLast
Results 7,156 to 7,170 of 12704
  1. #7156
    Feb 2013
    Does not worth to lose your time with it.... some times a clone is...badlly cloned and will find that after you open it. Just find cable with Atmega162 inside and come back for help to update, until that we can.t do nothing for you. This is it....
  2. #7157
    Jan 2011
    Quote Originally Posted by fedez View Post
    yes, am removed wires from GAL and used 0x46 files, flashed with ponyprog...I will try with USBASP
    so, am reflashed with USBASP. led not blnking, but same error, not pluged into car. Is that normal then connect usb there no led, after 12v led is green? maybe try connect GAL to chip and write 0x44?
  3. #7158
    Oct 2018
    I found Cable, CAN via VAGCOM_EEWrite.exe write eeprom and flash.Recommend to everyone.
    https://www.aliexpress.com/store/pro...953210304.html
    Without Cd and Sticker!
  4. The Following User Says Thank You to obdcarsale For This Useful Post:
    miouser (4th November, 2018)
  5. #7159
    May 2010
    EU
    ^^ I would not recommend it. Look at Q1, Q2, Q3 and Q4 transistors in your picture in Ali link.
    Cable like in attachment is far better.
  6. #7160
    Mar 2018
    Quote Originally Posted by kaalis View Post
    ^^ I would not recommend it. Look at Q1, Q2, Q3 and Q4 transistors in your picture in Aki link. Also there is NO protecting diode near obd2 connector (usually marked as M7, see it below).
    protecting diode ss14 post # 7158
  7. The Following User Says Thank You to Roma77 For This Useful Post:
    kaalis (3rd November, 2018)
  8. #7161
    Jan 2017
    HongKong
    Hi, dear friend, Obd2 car tool online store to complete the upgrade, order history name and email already encrypted. Thank you all friends.
  9. The Following User Says Thank You to obd2cartool For This Useful Post:
    manedi (3rd November, 2018)
  10. #7162
    Jul 2016
    Denmark
    Hello, i reflashed my cable to 1.96 vcds 18.9.0 Nez K line works good but it cannot scan CAN? Cable light is red with it have 12v?
  11. #7163
    Oct 2018
    your PCB used L9637D,but the chip is cloned and the FT232RL chip also is cloned, and i have same cable, write 5 times, the computer has not recognized usb.
  12. #7164
    May 2010
    EU
    Yes, of course... i have flashed it numerous times with older and newer loader versions and guess what, it's still ok.
    You should return it to seller and get another that doesn't die that fast.
  13. #7165
    Feb 2013
    Quote Originally Posted by obd2cartool View Post
    Hi, dear friend, Obd2 car tool online store to complete the upgrade, order history already encrypted. Thank you all friends.
    Since you started this discussions let me tell you I apreciate the transparency but beeing ablle to see almost the full name of the customers I think it is not that ok, you can show the initials of the name and will be fine with that...
    The blur was addet by me...so the second part of the name is fully and is public..
  14. #7166
    May 2010
    EU
    obd2cartool: Could you edit 16.8.4 DIY cable description because it has Palce chip in product screenshot but Atmel 16V8B in description? Thanks.
  15. #7167
    Nov 2018
    Nice to see, thank you.
    You could also **** more of the name. No need to see family names or so in the list.
  16. The Following User Says Thank You to manedi For This Useful Post:
    alexm1 (3rd November, 2018)
  17. #7168
    Apr 2018
  18. #7169
    May 2010
    EU
    Only if you can ignore price and bullshi# about mlb2 cars, 99% and original plan in description.
  19. #7170
    Apr 2016
    Thanks but not enough.
    Do what ebay does: just display first and last characters of the buyers name like this:
    a***n
