Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Newbie help
  1. #16
    Jul 2008
    Yes, I said in my post that I have tried it. Does it have anything to do with the images? What image is good for the dm500c?
  2. #17
    V.I.P. Member westkill's Avatar
    May 2008
    try the digital kaos image do an automatic scan
    Digital Kaos - Downloads - Digital Kaos v1 Image for DM500 (cable and sat)
  3. #18
    Jul 2008
    Bingo m8,/
    Services are plenty but only basic bbc, itv chanels are showing, I'v been to the addon manager and download some Ccams, Mgcams etc and have restat the box but still the same. Where do I get the Keys to download?
    Thanks again;;
  4. #19
    May 2008
    download from here
    RapidShare: Easy Filehosting
    unrar the file look in the key folder
    you will see two files one called keys and one called scce
    now you need to setup a ftp programe and transfer the two files sepratley into the dreambox
    once you connected to the dreambox you will see a tree of files
    so click on a file called /var/ transfer the key file over and then the scce file over
    then you need to restart the dreambox
    then chose one of the cams use evocamd then start it.
    goto a encrpted channel leave for a couple of minutes and hopfully you should see a picture
  5. #20
    Jul 2008
    Well,
    One thing about me is nothing goes right the first time. My dm7025 is up&running, all services are showing after a long wait. Thank God and you.
    My only prob is, the dm500c is pulling my leg a little bit as I can't find where to select and restart the Cam after downloading the keys you recomended from rapidshare using Dcc. I'm using the Kaos dk-Image.
    Thank again;;
  6. #21
    May 2008
    i have not got a dm500 but i guess its via the blue button
  7. #22
    Jul 2008
    Thumbs up
    End of my story,
    The emu selector and restart is actually under the Info button by press and hold. Both dm's are up and running thanks to your genious self.
    I hope this helps a lot of members. Until some other prob, I say; Buy for now.
    Thanks;;
  8. #23
    Jul 2008
    Default DVB-C Tuner Problems
    HI, can anybody help this newbie please. I live in Liverpool and need to know what settings I put in on my DM7025 to scan for the telewest services. Any help would be reatly appreciated. Thanks You In Advance.
