Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Default How to backup an image on the dm600?
    l want to update my image l have in downloads , but for the life of me cant remember how .. lv backed up the dreambox . but how do l make a backup image to pass around ? cheers for the pvr 600
    Member mic_mic's Avatar
    Apr 2008
    smirnoff you are a saint for trying to do this. Many people will kiss your feet
    Administrator
    Devilfish's Avatar
    Feb 2008
    I've not got a DM600 but found this for you to try.
    Copy the three files included in the archive to "/usr/bin".
    After that you have to set the rights to 755 for all three files to make them executable.
    To start the script you have to enter "build-nfi-image.sh DIRECTORY". DIRECTORY is the place,
    where the .nfi file will be build, e.g. "build-nfi-image.sh /media/hdd" will place the backup on your harddisk.
    About 50MB free space is needed and the Box must have an internet connection to load the Secondstage-Bootloader from DMM.
    Maybe the 600 owners know a better way.
    Administrator
    Devilfish's Avatar
    Feb 2008
    Here's another backup script, thanks to mrdude!
    No need for the receiver to be connected to the internet for this to work.
    How to:
    Ftp the included files to the dreambox root dir.
    Chmod all the files in usr/bin to 755
    Chmod /usr/lib/tuxbox/plugins/flexmenu.so to 755
    Chmod /usr/lib/tuxbox/plugins/flexmenu.cfg to 644
    Chmod /etc/tuxbox/config/shellexec.conf to 775
    Once done - press yellow on the dreambox remote control to bring up the plugin menu.
    Select 'Backup Your Dreambox'.
    The backup process will take a little while - once complete your new image backup will be created in the /media/hdd folder.
    Use dreamup - to flash back to the dreambox or you can do it the fast way like this.
    Make sure you have some way of giving the dreambox an ip address (connect to a router for example)
    telnet into the dreambox and enter these commands.
    mount /boot -o remount,rw
    rm /boot/*
    reboot
    Once the box has rebooted - it wont appear to come on, just enter the box ip into your internet browser, you will see a web interface to flash the box - use your image, this takes only a couple of minutes - once complete reboot the dreambox and that's all folks.
    Mar 2008
    birmingham
    well u lost me on the third line there m8 .. is there a plugin l use then , theres lots of files in the bin folder ...
    Administrator
    Devilfish's Avatar
    Feb 2008
    The plugin is attached to the thread m8. You need to ftp the files to the box in the locations stated and then use the plugin to create the backup.
    Apr 2008
    hey kaos is mrdude still about at all.???
    still using one of his first images of pli which was from the cave for the 600pvr...
    one excellent image....and with his pulse skin...its superb.....
    miss his input and images since the cave got rid of the you know what.....
    Administrator
    Devilfish's Avatar
    Feb 2008
    I think he sold his 600 a while back so probably fell out the scene a little.
    Apr 2008
    oh right... pitty really as he made some very good images when there was nothing around for us 600pvr owners.......
    May 2008
    Is there any way to backup the 600 without a hard drive installed ?
    Mar 2008
    birmingham
    l backed mine up its over 20mb , l have it mounted to a drive aswell so if l record it goes to the pc , dont ust the internal drive , but anyway the backup still saved there and not my mounted disc . looks like u will need one for that
    May 2008
    Seems like I will need a Hard drive to backup the image properly.
    Have tried a number of methods but none work properly .
  13. #13
    V.I.P. Member satman's Avatar
    Jun 2008
    Never Never Land
    Quote Originally Posted by Fano View Post
    You need a hard drive,, or use a network mounted drive before you can do a full 600 backup,,,,
    telnet the way to go i always believe cant speak for the plugins but fairly easy to get a full backup of a 600 ...
    boom!
  14. #14
    Member fishy123's Avatar
    May 2008
    Quote Originally Posted by Devilfish View Post
    this method works a charm for me. thanks devilfish
  15. #15
    Member bub's Avatar
    Aug 2008
    I would appreciate some help on this part of backing up image please. 'Chmod all the files in usr/bin to 755'
    what files am I supposed to CHmod?
    what is Chmod?
    where is 755 folder?
    bub
