Results 1 to 3 of 3
    Jun 2008
    Default neutrino aspect ratio
    I have an original DB and a clone I'm using a neutino image on both of them, the clone is fine but there is an apect ratio problem on the original. I have only noticed this since putting it on an old 4:3 TV. No matter what I set the AR to it ends up with the wrong AR. For example if I set it to 4:3 LB it is fine until I switch to a channel with a 4:3 AR then go back to a widescreen program and then AR is wrong. This only happens with the original genuine DB not the clone,Sorry if i've not explained very well. I do seem to remember ages ago reading about some sort of Aspect ratio problem with neutrino images perhaps this is it.
    Mar 2008
    Coatbridge
    My dad used to have this on his cable DM500 (Genuine) when he used a 4:3 tv which didn't support aspect ratio defining, he later upgraded to a 16:9 tv which had an option to select aspect ratio and the problem ceased.
    Prior to his purchase of the 16:9 tv I took the box and tested it on my 16:9 tv and it worked great, perfect ratios at all times, I then out it on an older 4:3 tv and again the ratios were wrong.
    For me, I've never sussed how to get the correct aspect ratio on certain 4:3 tv's, some seem to handle it ok and others simply don't!
    Jun 2008
    That's exactly the problem I have, it's no big deal i'll just swap them about and put it back on the widescreen tv with auto setup. Seems to be a problem when using the new driver.
