hello friend... scanner with clear faults and be happy :l?grimas de alegria:
Good evening!
Friends,
Please, I need help clearing this file Jetta 5C0 959 655 C.
Can someone help me?
File tested will be greatly appreciated as the car is far away.
Thank you very much in advance.
In case my help has been useful do not forget the magic buttons. ( Thanks and * Reputation ) !!!.
ATTENTION!!!
Attempting to clean files is only to help members. By using these files, you agree to assume the consequences and are aware that all liability for any damages is entirely yours.
Thank you!
megabits.
megabits (28th June, 2017)
Do the tests friend and post results
5C0 959 655clear.rar
ATTENTION!!!
Thank you!
megabits.
ATTENTION!!!
Thank you!
megabits.
Hi, friend, try this file or other virgin file to coding, report back, pass in pm.
Best regards.
Dragon
megabits (5th July, 2017)
Please, send me pass.
Maybe one question - VCDS dont want to clear faults. Did you replaced airbags like error ( head, front ) , did you replace courtain ? Belts ? Belts tensioner ?
In my case, I need uncoded dump.
VCDS must clear all faults after replace broken parts.
