Flashed Sagem 1chip with 2ximage
  • robbeye
    • 21
    I have flashed a 1 chip dbox with a 2x image and the box won't boot but the lcd lights up but nothing else. Can someone give me advice on how to fix this problem I have tried a null modem flash but gets to the end to cp.1 120000 10020000 1F8000 enter this and get this => and nothing happens. Does someone know how to get the box up and running again.
  • jitjunior
    • 93
    Re-flash using Image Flash assistant . if you used the X2 image use the X1 image instead.
    IFA is available here
    Digital Kaos - Downloads - Image Flash Assistant (IFA) v3.0 RC2
    It is best if you have a null modem cable when using IFA because you can see what is going on. It can be done with just a crossover cable, although it really comes down to timing and when you turn the dbox on, it may take you quite a few attempts ( it's not unusual to be around 50 times or even more!) but it does work. If you have a null modem cable then it will be an easier job.
    IFA is pretty simple to use, just follow the instructions on the screen.
    Good luck with it!
    P.S. try sourcing your image from the chatterbox toolbar
    The Falkirk Wheel...... It's the best we can do!
    • unrealegg
      I had this problem before and used IFA, worked like a dream! Use it all the time to put new images on now
      • valvecoding
        • 26
        IFA is the key
        if you have problems use the ifa 1.56, its very old but does the trick, it gets through anything, i did the same last night with my dbox ,put the wrong image on, (THE KLEIN SYSTEM), could not do anything with it. it boots up a little different. but installs the image. i used a cross over. i do not know if works with a nul modem. dont worry help is out there.
        • finbar
          I did this with my box and found the only way to recover the box was to flash a x1 image using the null modem cable method,it takes an hour or so but works a treat
