Hi I have just tried flashing a new image to my dbox and on reboot it has locked up ie the screen is frozed even after unpluging and switching on again any ideas
Thanks Keith
Your only option is IFA m8, best to use it with a null modem cable but if you dont have one it will work with just a crossover cable but can be hit and miss and may take you a good few attempts.
Image Flash Assistant. go to the download section, Dbox and other. you will find the IFA. try to use a router if you are not good with Network settings.
