Please help an idiot out
  • MightyMouth
    • 19
    Hi all,
    I am a noob with a DBOX2. I have tried following all of the guides I can find but I cannot seem to get anything but FTA so I must be missing something.
    Basically what I have done is loaded Commando 10b then copied evocamd217c to emu and These files to the correct location I think then rebooted on sky sports 1 and left for ages but I still only get FTA.
    Do I need something else? Is there an easier way or an easier image?
    Please help
    Now Fixed, Thanks MetMan
  • MightyMouth
    • 19
    Ok thanks, Ill try that, I didn't see a fta only option though.
    • MetMan
      • 1091
      too many dreamboxes for aftermath.. or enigma imgs i guess
      check ur emu attributes like A-M has stated
      • aftermath
        • 4345
        Yep i better get my glasses out the cupboard, what was i thinking of,
        • Knockoff_Nigel
          • 69
          Did you chmod the cam files to 755?
          • MightyMouth
            • 19
            I did try but for some reason I am having problems with FTP, I am uploading files and they only partially upload so the file sizes are different and then when I try to upload again it is failing, my chmod is failing also and I cannot delete the file which did upload. I have tried both manually setting the IP and connecting with a crossover cable and setting to DHCP and connecting via my router. I have tried uploading from both my PC and my laptop. same thing happens no matter what I do. I am using Filezilla.
            • Derekwd
              • 244
              Sounds like your image as gone read only m8, reflash it again and start from scratch.
              Derek
