Flashing a Dbox2 using A Null Modem Cable and Hyper Terminal
  • aftermath
    • 4345
    #121
    Originally posted by stuckylad
    when typing in chorus 800000 nothing happening,any suggetions ? cheers
    try copy and pasting from the tut, it can be easy to miss a character off or something.
    • stuckylad
      • 991
      #122
      sorry ,trying to copy the usual way ,but cant seem to paste
      • stuckylad
        • 991
        #123
        getting elf copy failed,after typing chorus 800000,about ready to throw this thing in the bin grrrrr
        • woonker
          • Jun 2009
          • 17
          #124
          Originally posted by chuckles53
          got to the part were you have a blank screen and when i held the arrow down and turned the box on nothing happend,can you help.Thanks
          when you get to the black screen in hyper terminal then plug in your null modem cable and press the up buttom and keep it pressed and then plug in your dbox and you should get the text in hyper terminal,
          ps big thanks to aftermath for the tutorial and the screen shots they realy helped me out.
          • NUKEMALL
            • 84
            #125
            thanks for this info lads and great work .
            killed my box friday night trying to find a stable image for my sagem (old but i like it) .
            i was using the Lincsat.Beta7.25-Full image but it keeps freezing and i need to restart it to get it to work again so i tried to flash a image using my network and yes crashed the box . copied you post word for word and got it running again .
            THANKS AGAIN FOR THE HARD WORK YOU ALL PUT IN FOR US NOOBS .
            can any one pm me where i can get a newer complete image i can play with .
            • macaco
              after installing the uboot i gote this
              unrecognized command ???Y??? r, args[0][0] 0xea
              dbox2:root> x{~???@??tB??BB?B???B???B??B?????$??CD??C??Ct????C ???C?????C????
              ??C????$?D4??DT??Dl??D???D??D???D??D???E???$?E<??E T??Et??E???E??E???E??E??????
              2x{~???@??tB??BB?B???B???B??B?????$??CD??C??Ct???? C???C?????C???C????$?D4??D
              T??Dl??D???D??D???D??D???E???$?E<??ET??Et??E???E?? E???E??E???F??$?F4??FT??Fl g
              DT??Dl??D???D??D???D??D???E???$?E<??ET??Et??E???E? ?E???E??E???F??$?F4??FT??Fl
              gnant5nd/d t=b=e080 80ete0d29e87e2.beg????
              unrecognized command 2x{~???@??tB??BB?B???B???B??B?????$??CD??C??Ct???? C???C
              ?????C???C????$?D4??DT??Dl??D???D??D???D??D???E??? $?E<??ET??Et??E???E??E???E?
              ?E???F??$?F4??FT??Fl gnant5nd/d, args[0][0] 0xa0
              dbox2:root>
              dbox2:root> ??:??k??j????/????"????lj???@_??B????
              unrecognized command ??:??k??j????/????"????lj???@_??B????, args[0][0] 0x80
              dbox2:root> ???????6??
              unrecognized command ???????6??, args[0][0] 0xea
              and i clik enter and then the commande
              chorus 800000
              and got this message
              dbox2:root> chorus 800000
              chorus 0x800000
              elfCopy failed: 16
              dbox2:root>
              and nothing more
              plaise help me
              • NUKEMALL
                • 84
                #127
                stuckylad getting elf copy failed,after typing chorus 800000,about ready to throw this thing in the bin grrrrr
                follow the TUT as shown if you are copying and pasting as norm all should be ok .
                i am new to the dbox , as playing for fun at the mo ... but i have used this for atleast 6 flashes and at first i had loads of trouble BUT . started from step one and followed the tut and now its like childs play , just have the tut open for the cut and paste ....
                great work lads
                • MB2008
                  • Oct 2008
                  • 12
                  #128
                  Can you use this to flash the d-box nokia. I dont have d-box2
                  • jazzymeme
                    • 13
                    #129
                    hi
                    im a newbie wanting to know where to download the u.boot.mot file please thanks for the help
                    • add1711
                      Most comprehensive guide i've found
                      many thanks best guide and site i've found on the subject, cant wait to get stuck in, great stuff!
                      • gaari
                        • 6
                        #131
                        could you tell me were i can find to download u-boot.mot
                        • owenpaul36
                          Thanks for putting this info up.
                          I've tried several times, holding the up buttton while powering up
                          I get the following, displayed on Hyperterminal
                          But thats all that happens, I'm unable to type anything.
                          When I do, the curser remains in the same place and nothing happens.
                          Any ideas whats happening?
                          ~debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
                          debug: LCD init error -1
                          debug: BMon V1.0 mID 01
                          debug: feID 7a gtxID 0b
                          debug: fpID 5a dsID 01-58.4e.cb.05.00.00-61
                          debug: HWrev X5 SWrev 0.81
                          debug: B/Ex/Fl(MB) 16/16/08
                          WATCHDOG reset enabled
                          debug: &_text 0x10000, &_etext 0x26160, &_data 0x26160, &_edata 0x29c50
                          debug: &_end 0x347dc, &__stack 0x400000
                          debug: Memory tests (0x400000 -- 0x1000000)
                          debug: NumberTest: debug: passed
                          debug: MarchTest: debug: passed
                          debug: PermTest: debug: passed
                          debug: Extension Memory tests (0x1000000 -- 0x2000000)
                          dbox2:root>
                          • deejay_waz
                            • 11
                            #133
                            Hi guys once its says "DONE" what are the nexts steps????
                            reallly appreciate your help!!
                            waz
                            • deejay_waz
                              • 11
                              #134
                              can someone assist me with what the next step is after it says "DONE" i live in the TW3 region (london). by doing the steps AfterMath has stated, do any need to do anything else?
                              waz
                              • donqam
                                • Mar 2010
                                #135
                                thanks, sounds good, i will see how this works out
