Trouble with FTP
  • MetMan
    • 1091
    #16
    Originally posted by espesso
    changed from auto to 10mbps/half mode. still unable to ping. any ideas why i have only been able to connect usuing null modem? have used cross over in past to flash and no probs
    what img u using? cant think of reasons why u can't connect thru router with a normal ethenet of direct with a crossover.....try using the pc - router cable...swap them over just to eliminate the cables....
    • Validus
      • 14
      #17
      Another idea is to change the dbox's IP address again on the router as there might be another device that is connected to it and using that same IP. Best thing to do is if you have a few devices connected in the house is to "Ipconfig /all" them all. Then you know what IP's are not avalible to you and then you can use one that is open . If you are currently choosing an IP that is being uesd it will not connect to the router without that device off as the IP is hard coded.
      My only idea from work in other IT areas this always annoys me with my laptop onto different networks.
      • espesso
        • 15
        #18
        using commando 10 x2, have tested cables and are ok. checked ips, no conflict
        • MetMan
          • 1091
          #19
          any other network adapters?
          • espesso
            • 15
            #20
            turned them off
            • Derekwd
              • 244
              #21
              Did you remember to change password to commando in you ftp prog
              Derek
              • espesso
                • 15
                #22
                have done that Derek, makes no dif as i cant get box on network, ie unable to ping
                • Derekwd
                  • 244
                  #23
                  Sorry m8 thought you could ping box as in your first post you wrote (when I test network now dbox is reachable (ping)
                  Useing belkin myself no probs at all, strange how its good for some and not others
                  Derek
                  • Validus
                    • 14
                    #24
                    You have said before that you can use a null modem cable fine. So if this is a working method why dont you just do that method instead of using your router and crossovers?
                    • MetMan
                      • 1091
                      #25
                      is ur dhcp server the same addy as ur router?
                      maybe worth trying a static address
                      • espesso
                        • 15
                        #26
                        dhcp isn't enabled. Does anyone know if hyper terminal can be used to ftp missing files?
                        • Validus
                          • 14
                          #27
                          From looking at the guide it doesnt look like the easiest way (even if it is possible which i am not sure). Im just having a google to see if you can ftp through the null modem cable.
                          edit:
                          Null FTP Server Pro 1.0.7
                          That program looks like something worth taking a look at.
                          • espesso
                            • 15
                            #28
                            thanks to all for their help, finally found a fullish image to flash using null modem cable
