How do I get into a Digivox ?
  • NOTaCLUE
    • 38
    I can get into a Dbox 2 but have not idea of how to get into a Digivox or where to start.
    Any help appreciated
  • cloudnineuk54
    • 530
    get into? well if flashed,its factory reset,then scan,then, menu/system info/press ok/type in 1004/turn emu to on/hit ok on set default k*y exit out let it update on sly sp 1. if not flashed you need the latest firmware and downloader 10. power off hit download then power on.
    • DW190
      If you are looking to ftp you can't
      • NOTaCLUE
        • 38
        When I hit Download I get this message " Fail to update Flash! "
        Any ideas
        • pieman
          • 6
          try changing ur com port is it xp or vista i had that problem with my laptop running vista it was fine on my tower running xp com 2 hope this helps
          • NOTaCLUE
            • 38
            I changed the port and It starts to flash the box but then 10 seconds later It says failed
            I have a Vista PC
