cant get media player to work xp
  • webba
    Hi all I am a comlete dbox newbie.
    I have got my dbox2 working fine all channels ect but I am having real problems getting media palyer to work with my pc. can some one point me to a step by step guied or explain step by step how you do it .
    I have my dbox conected to my router I have pionted media player at the ip of my pc and set the defult gateway to my routers ip ,I have turned the firewall off on my router and made a folder c: movies on my pc .
    if I test settings in networks everything pings fine but if i try to use media player it hangs and says server not found.
    I have sporster 1.0 uk on my dbox2 and I am running xp prof sp3.
    I recon it is proberbly somthing simple and im just being dumb ass . but I need help before I pull my hair out PLEASE
  • Frederick
    • 90
    i think you need to share the folder as well
    • on_the_jazz
      • 557
      You need to share the folder on the pc and then mount it through the dbox2.
      • brandon2004
        bump bump bump
        • bobsylas
          • 53
          Originally posted by brandon2004
          bump bump bump
          Nice first post
          • webba
            still no joy I have installed neutrino tv and that dose not work when i first tried it it worked fine after the first go I have been unabe to make it conect it says dbox activly refused conection. also yweb wont let me view live everything else works fine but if i try live view i just get the vlc cone in the viewing window but thats it. I am truely puzzeld and would be VERY gratfull if someone can help me.
            at the bottom of the screen on neutrino tv it says " this is NOT a neutino image neutrino tv only supports neutrino image
            ok just copied these from log file
            12/07/2009 16:07:49: 192.168.1.100 GetImageVersion: Communication error while trying to get the version from the box: No connection could be made because the target machine actively refused it 192.168.1.100:8080
            12/07/2009 16:07:49: 192.168.1.100 [INIT-BOX] > This is NOT a neutrino-image! Currently neutrinoTV supports only neutrino! Aborting..
