SAGEM DBOX - help!
  • ds1210
    • 10
    SAGEM DBOX - help!
    Hi Guys,
    I bought a sagem dbox2 from ebay over 1 year ago.
    all i got was the box, remote, scart lead and power lead
    i connected it up to my tv... its started working and we got all the channels..
    1-2 months back all the channels were still there but no picture.. i went on the net as you do and see if i was the only one.. but everyones boxes went off.
    since then i am not good with these things.. i just took it off and left it..
    i have just decided to give it a go.. see if i can do it..
    when i switch on the box on the LCD it says:
    comes up with lots of letters and numbers.
    then
    StarTrek
    Loading Kernal
    then
    Neutrino NG
    Phenix One (is this a channel name?)
    i don't have any cds or anything can anyone help?
    would need step by step and screen shots...
    i am very bad at these things! i can't believe i am trying this... i have read loads of posts.. images? etc don't make any sense...
    anyone got any time for a complete 1st timer.. ??? would appreciate it... sick of the boring analogue tv!
    Regards
    Adam
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Sounds like you need new auto update files. The cable company sends out keys along with all the channels, you need these keys to view the premium channels. A program runs on the box to grab the keys from the stream and it uses them to show you the channels. The method of grabbing the keys changed on 8th April so you will need new files to make it work again.
    You will need to connect your dbox to your PC in order to transfer the files to the box. You will need a crossover ethernet cable (?3 from ebay) to connect the dbox to your PC.
    You will get the files you require here...
    Ok guys and gals...I know some of you are still having problems with the auto updating of your keys. You will need to be comfortable with ftp'ing files to your dreambox for this to work. Delete everything in your /keys folder. Extract the /keys folder from the rar. Copy the contents of this keys folder to your own keys
    And there's a guide for connecting the dbox to your PC here...
    It's for a dreambox but it's exactly the same for a dbox2.
    Good Luck
    • ds1210
      • 10
      Thanks! i will give it a go....
      <--ds1210 added 0 Minutes and 39 Seconds later...-->
      do i have the latest software etc?
      • father ted
        • Feb 2008
        • 1389
        the image you have on may be ok ,its just you mite need teh latest files ,but as devilfish say`s youll need to link it up to your computer
        • ds1210
          • 10
          i can't download the FlashFXP file.. it says i don't have permission?
          how do i get permission?
          <--ds1210 added 161 Minutes and 40 Seconds later...-->
          Hi Guys,
          after the last 3-4 hours trying i have managed to connect my computer to the D-Box via FTP!
          RESULT!
          i have then clicked on the keys and deleted everything in that folder and replaced with the Keys file that the Devil uploaded on another post (followed the link)
          i have now rebooted the system... connected everything up and i get all the freeview channels but non of the sky movies etc...
          what have i done wrong? do i need another key???????? are my settings wrong?
          guys Help! stuck again!
          Adam
          • Devilfish
            Administrator
            • Feb 2008
            • 7872
            Are you using evocamd?
            Check the BLUE button menu, there should be an option for EMU Selection or similar.
            Go to Sky sports 1 and restart the emu if you can via the blue button. Then flick to sky sports 2, wait a minute then flick back to sky sports 1. If it doesn't come on after 1 minute then reboot the box again. You must use evocamd or mgcamd but I would suggest evocamd.
            • ds1210
              • 10
              Hi Guys,
              i am running evocamd.
              it now gets stuck... on the channel no pictures or it flickers alot... i have tried the restarting on the evocamd lots of times.. i even tried newcamd and mg... no result.
              when i did a service scan it comes up with 188 channels
              don't know what to do now? any ideas?
              • father ted
                • Feb 2008
                • 1389
                Hi Guys,
                try changing the ucode
                • ds1210
                  • 10
                  How do i change UCODES? and what shall i change to?
                  • gizmo.1484
                    • 873
                    To change the ucodes press blue button go in to settings then go to ucodes selection, go to ucode 001a and press ok then restart your dbox. If this does not work try one of the other ucodes.
                    • ds1210
                      • 10
                      tried all the ucodes.. no luck...
                      i also checked signal strength over 64000
                      any ideas?
                      <--ds1210 added 85 Minutes and 20 Seconds later...-->
                      here is the latest with me...
                      i have now just checked the bouqet.. its empty just one listing in there..
                      also when i now scan it inds 188 channels but does not show the providor and name of channel...
                      and now no channels at all.. whats happening... is it time for a new box?
                      Adam
                      • gizmo.1484
                        • 873
                        You need press the blue button and set your location then try another scan if that does not work then download service & bouquets for your area from downloads
                        • ds1210
                          • 10
                          when i press the blue button...
                          it gives me option..
                          am i changing scanning option? what frequency shall i put in?
                          there is services for bolton but no buquet
                          • gizmo.1484
                            • 873
                            Go to service scan then change bouquet to create new, Then change cable provider to 6952 if on telewest or 6887 if on ntl turn, scan mode to complete then turn fast scan off, you can edit bouquet with bouquet editor
                            • ds1210
                              • 10
                              its picking up 188 channels.. but its does not show providor or channel name.. and when i go on the channel.. nothing...
                              do you think something wrong with my cable?
                              Adam
