Nokia Dbox2 Not getting any channels
  • tvadict
    • 363
    Im new to all this so please be cool with me.
    I bought a nokia box from germany and when it arrived i flashed it with commando 10d x2 image i got from my friends working box. So all the keys, cams, etc are there already. Upon scanning for channels the box is getting 303 transponders and after finishing scanning them all, no TV or radio channels are found. ZERO.
    Tried it on my friends feed and the result is the same.
    Where am i going wrong? Is the tuner not getting the signal? or i need to put more files into the box.
    I have set my location correctly
  • cgscott
    • 3513
    Did you back the image up from his box properly.
    The best bet would to manually ftp the files over so you know they are in the image.
    Patience is a virtue.
    • plasterer
      • 1631
      When you transferd the back up image at your mates
      Does it work there
      No Need to scan at his location,should work right away
      Try it direct to the wall no splitters
      and report back ..................Paul
      PAUL
      • tvadict
        • 363
        but at least i should be getting the channels then fail to view them.
        isnt it that just an image without any keys, roms, cams, etc will scan and find channels?
        • tvadict
          • 363
          my connection is direct to the wall. my mate is watching tv using the same image
          • victor1
            • Oct 2008
            • 83
            Are you sure your box is the same as your m8s could be you need a 1x image when your m8s is 2x or vice versa.
            • pacmanx
              What about diseq settings?
              • Donka
                • 184
                where you getting any fta, if not it could be tuner probs. I had a prob like that and discovered my input connection to tuner was lose and got it re-soldered, but it done the same thing and when scanned got all transponders but no channels. Hope this helps a little.
