anyone know what images have got the new now and next, which is ghosted when you go to next.
dbox 2 image
Do you mean the sky infobar mod...i.e. press ? to bring up the infobar then scroll left and right through the epg for different channels while still watching the current channel?
I think this feature is build into the CVS so any new images from about 8 months ago will have this mod. I might be wrong though but I think that's right
The images are in the download section, however, you need 5 good post to enable the privilege of u being able to download.
just take your time, read up on other threads and posts.sigpicComment
The image has flashed successfully? i think its because of there are no ROM files within the image due to recent events. Go to the link below, download the files and extract them.
Click Here
then connect your box via FTP and put all the contents of the above into the /var/keys folder on the box.
Reboot your box go to Sky Sports and just wait a minute for it to clear. it mite be instant or take a bit of time.
hope that helps,Last edited by Erazor786; 1 June, 2008, 19:26.sigpicComment
sagem 1xchipset
I know how to flash the box tried various images and every time it says "no channels were found please execute a scan" i try this with cable privider set at bruteforce as i have another dbox and thats wot thats at.it scans and pick up no channels, not even free view. I cant use the image off my other box as it has 2chips.Comment
You can not from here, because of legal reasons. try this m8, connect your other box with all the bouquets sorted. go to var/tuxbox/config/zapit folder and there should be 3 files:
"Bouquets.xml"
"Services.xml"
"zapit.conf"
transfer these files on to your computer, disconnect the box and then connect the one with no channels found. go to the same directory /var/tuxbox/config/zapit and transfer the 3 files you just FTP'd, onto that box.
and also transfer the files that i pointed out to u earlier (rapidshare link) into the /var keys folder.
Disconnect the box and Reboot it.
Leave it for a minute and it should clear and should worksigpicComment
Anyone know where i can get an image for my sagem with 1chip? its drivin me nuts!!! I live in scotland if that makes any difference.
