broken antenna
  • staggers
    • Apr 2009
    • 149
    broken antenna
    hi all my sons managed to break the connection on back of his nokia dbox2, as i have not got a clue how to fix this i was wondering would a tv repair shop fix this and if so would i need to put a new image on it once its been repaired ,and anyone got a rough idea how much this would cost ?hoping no more than ?30. tx stags
  • moin
    • 178
    no shop
    mate u wouldnt want to take it to a shop u probly get done for this because it is criminal offence using any other typ of recievers from other countrys
    • plasterer
      • 1631
      Get one of these from maplins and solder it in
      Couple of quid max
      Do it right and its as good as new.................Paul
      PAUL
      • phils_confused
        • Mar 2009
        • 11
        I just used a big fat soldering iron to reconnect the outer part. Then a fine pointed tip to do the internal part.
        • Cush
          • 7
          Couple of quid max
          As the man said its not too hard m8 I managed it and im not much good wiv a solder iron
          • Donka
            • 184
            I had one fixed in tv repair shop last month cost ?20 and works fine.
            • staggers
              • Apr 2009
              • 149
              tx all for your input , thing is i have never done soldering so not confident in trying, can anyone recomend a shop that might do it in scotlands capital tx again stags
              • portbhoy
                • 717
                Take it to any repair shop they'll do it if your worried remove the info from inside k*ys and scce then it's FTA but I've never heard of a repair shop grassing someone up
                • PaphosAL
                  Old Git
                  • 1064
                  Couple of quid max
                  FE98G @ 99p Paul
                  But it's an expert soldering job, requiring a big ~~~~-off iron, m8!!
                  Cheers- AL
                  • mickyrobbo
                    • 34
                    What a load of bull,if you dont want to have a go at it,just take it to any repair shop most anyway probably up to no good anyway ,they probably would,nt even think that you have to put a male connector onto a cable feed anyhow
                    • HGV_DIAG
                      • Aug 2009
                      • 192
                      if your taking it to a shop you might aswell see if they will fit the proper f type connector or whatever it is to screw in like the proper box as ive got similer probs with a loose connector on the back, it keeps coming out.
                      • chizzy
                        • 10
                        I'll have a look at it for you if you like. I live in Scotland's capital and work in electronics so soldering is not a problem.
