help with n2 fix nokia dbox2
  • Tommo1973
    • 181
    #16
    Originally posted by keith20_06
    Tommo i think your right it certainly does sound like a signal issue. it is a direct cable feed with no splitter or anything so its unusual. do you know any way of checking signal? if i do happen to get it going do i need those 'magic files' you posted above or should image you posted above work as is? im in dublin as you know. thanks Tommo
    Do you have a broadband or tv subscrition if not then it is likely the feed is dead.
    If you have a virgin box or a mate with a dbox you could try that on your feed, or take your box to a mates with cable installed and try it on there feed.
    Tommo
    • plasterer
      • 1631
      #17
      It would Appear All ireland has gone down for all boxes
      D Boxes Itgate and Dreamboxes Possibly N3 has Dropped in
      Just have to leave your boxes as they are
      And see wot Develops
      They may be testing and revert back.....................Paul
      PAUL
      • khaos
        • 4
        #18
        tommo, your a star m8, thats me up and running, done the "real magic" and was up and running in 10 mins, had a fair bit of experience with sviews and eurov*xs etc but the linux bit with the dbox got ma head screwed for a bit, aint used linux for years
        anyways, all good to go now, didnt realise the chmodding was so important
