please help
  • willowtrousers
    • Aug 2009
    • 5
    please help
    Hi all,
    I have downloaded & installed the latest blade quad (thx xenafan) have also got keys and cams copied into /var/keys and /var/bin/emu.
    Have set location, rebboted and scanned, yet still only fta. Can't even watch Dave!
    Am I missing something??
  • Tommo1973
    • 181
    Have did you chmod the cam files?
    evocamd,mgcamd,gbox
    Tommo
    • boxxie1
      Originally posted by willowtrousers
      Hi all,
      yes m8t you will have to set ur location then scan job done
      • willowtrousers
        • Aug 2009
        • 5
        eeerrrr no how do I do that?
        • Tommo1973
          • 181
          ftp into the box and go to var/bin/emu then right click on each file in turn (evocamd etc) select chmod from the list of options then change the value in the pop up box to 755 and click ok.
          Once this is done restart your active cam and go to sky sports 1 and wait for channel to clear (should only take a few mins).
          Tommo
          • macjst35
            • Oct 2008
            • 113
            Hi in ur post u already set the location just don't reboot the box then do a scan
            • Tommo1973
              • 181
              I believe blade quad reboots automatically after the set location option.
              Willowtrousers,
              I did assume with you mentioning dave that you had found both fta and encrypted channels when you scanned and that the encrypted had not cleared??
              Tommo
              • willowtrousers
                • Aug 2009
                • 5
                I couldn't get it to work so I dropped back to an older image file and got it going with the new keys
                cheers guys.
                • Tommo1973
                  • 181
                  No problem glad you got it sorted.
