Commando 11.3 - Really the End
  • PaphosAL
    Old Git
    • 1064
    #76
    Originally posted by trapperdog
    is thi the latest image what ot?
    Ran this through BabelFish Translator, Double-Dutch to English, and it said YES
    • HypaSnypa
      • Sep 2009
      • 41
      #77
      Recently updated my commando 8 image with 11.3. Im not an expert flasher so I can only compare between the two.
      I see a slight improvent in picture.
      7 day epg is great although had to update my epg filter file to include extra channels other than the 1st 80 only.
      Sometimes needs restart when left on standby for a while as channels other than FTA disappear.
      Occasionally reboots without notice, something commando 8 used to do as well.
      Cant see the need for the event list overview (epg plus) when bouquets are already enough.
      Wake up from standby starts at full volume so wise to start wakeup on a quiet channel like pvr epg.
      Cant seem to stream to my pc anymore(using wingrab & vlc). Dont know if its anything to do with the DNS server ip in network settings which cant be removed.
      Other than the minor niggles a great image. Thanks.
      • PaphosAL
        Old Git
        • 1064
        #78
        You have overloaded your dbox's limited memory resources by trying to add too many channels to collect long EPG, m8. The side issues you are suffering are the direct result of this.
        Read the pdf that came with the image, please- and try to reduce the number of long EPG channels, NOT increase them!
        This is still ongoing development by FreddyFr0g, and the memory problem has been pinpointed. The culprits are all the Now ' Next only shite channels all collecting Detailed EPG Descriptions - and he's hoping for a fix very soon. The delay in fixing is down to the three cable providers each ignoring DVB Audio standards- and using their own apid descriptors!!
        Cydine is also now on the case, helping Freddy to 'commonize' the fix, so it'll work across the board, irrespective of whether you're in Pure, TW, or ex-C&W.
        The best short term workaround is to switch to Standard EPG Mode (up to 4 Days EPG).
        Cheers- AL
        • HypaSnypa
          • Sep 2009
          • 41
          #79
          Thanks AL, had already switched to 4 days epg as I also suspected what you confirmed...no problems so far.
          • HypaSnypa
            • Sep 2009
            • 41
            #80
            By the way, just noticed I am shown to have downloaded 7 times but I have been unable to download anything.
            I keep getting an error page;
            Warning: copy(./downloads/52841-Commando 11.3_2x_ package.rar) [function.copy]: failed to open stream: No such file or directory in [path]/downloads.php on line 704
            ERROR: File not found.
            I'm just looking for the standby volume fix for commando 11.3. Is it as an addon or is the full image updated?
            Thanks.
            • PaphosAL
              Old Git
              • 1064
              #81
              I don't think Standby Volume quite made it into the C11.3 release image on here, m8. Check in the Blue > Blue menu- if you don't see it, you ain't got it. In fact- it's not even in our release over on UkCvs, but still an add-in patch, LOL!
              Better update this on here, then...
              __________________________________________________ ____
              With mega thanks (as usual) to LraiZer for helping out with the sed part of the scripting (and for chopping the size of the script to a third of what it was!)
              Install is a peach! Extract the complete tarball from the rar file, and FTP it to the /tmp folder of your dBox2. Do not use WinRAR to extract the folders and files from the tarball !!
              Telnet in, and type these commands:
              /var # cd /tmp <enter>
              /tmp # tar xjvf sb-vol.tar.bz2 <enter>
              /tmp # /tmp/sbv-setup.sh <enter>
              /tmp # exit <enter>
              ...and that's it! No Reboot, no restart neutrino. Total added payload of this addition is about 1kb!! Enjoy...
              Cheers- AL
              • HypaSnypa
                • Sep 2009
                • 41
                #82
                Nice one AL ..."I'm Happy now!"
                • tasker
                  • Sep 2009
                  • 6
                  #83
                  great image thanks to all that worked on it just flashed it to my dbox best try put the files in hopefully get all the channels thanks
                  • Markcam24
                    #84
                    Hello, I am unable to download the image via downloads and get the following error:
                    • leefaster
                      • Sep 2009
                      • 10
                      #85
                      any news on fixing the download?
                      • HypaSnypa
                        • Sep 2009
                        • 41
                        #86
                        OK...Commando 11.3 has grown on me now and I'm very happy with it, but why can't I connect wirelessly to my pc anymore using using wingrab and vlc.
                        Tried dboxtv and stream me, & even explorer but cant connect to my box for streaming.
                        My settings are the same as they were since they worked on commando 8.
                        Is this a commando 11.3 issue, if so, is there a patch & will it be available 4 download here?
                        If not then what could I be doing wrong?
                        Cheers.
                        • HypaSnypa
                          • Sep 2009
                          • 41
                          #87
                          Doh! installed relevant addons....streaming working again!
                          Sometimes the answer is just staring u in the face!!
                          • scudno1
                            • Sep 2009
                            • 52
                            #88
                            dbox help
                            hi all new to the dbox side of things but i dont have a remote controll for the dbox do i need one to flash new image to box.any help would be great.
                            • mickydibble
                              • 2166
                              #89
                              Buy a remote!! You will need one to change channels,scan etc etc .... Fleabay
                              • mezmillion
                                • Oct 2008
                                • 30
                                #90
                                updated image with gbox as suggested but still have picture freezing , has anyone got any ideas as to why and what can i do to fix this as image is good picture quality
