new to dbox
  • skinterz
    • 89
    new to dbox
    alright
    ive got a 1x dbox2 with andromeda image,ive never flashed and image on it before and wanted to try the blade image .
    ive downloaded the dbox2 guide and understand i have to save the image i already have just incase i balls it up .
    im unsure about what it means by the FTP method ,ive dowloaded smartFTP and im up to Connect via your FTP Program to your box and copy the image to the main /tmp folder . do i put the image i want on the FTP program ?
    also do i connect the dbox using ethernet ?
    cheers .
  • plasterer
    • 1631
    When you connect Via ftp
    You will see your Image on the left hand side of you PC
    Were ever you saved it to
    On the Right is all the D Box Files
    Open the Temp folder on the Right
    Then on your pc side Right click the image and select Transfer the image
    is now in the Temp folder of the D Box
    Dont switch off the box till its flashed or you will lose the image
    Now do the Following on the remote
    FTP .img file to the /tmp folder on the box.
    Using remote...
    DBOX
    SERVICE MENU
    SOFTWARE UPDATE
    EXPERT FUNCTIONS
    WRITE ONE PARTITION
    FLASH WITHOUT BOOTLOADER
    Select the image from the list and select yes........Lets Know how it goes ..Paul
    PAUL
    • skinterz
      • 89
      cheers m8
      ill have a go of it and let you know how it goes .
      one more thing how do i convert the blade image to 1x?
      • plasterer
        • 1631
        Just Download the 1 x Mate .......Paul
        PAUL
        • gizmo.1484
          • 873
          Originally posted by skinterz
          cheers m8
          You can convert a 2x image to 1x image by using the image converter in downloads.........................
          So download the blade image 2x and use the image converter to make it 1x then flash it to your box. You can do this with any 2x image
          • plasterer
            • 1631
            You Cant convert SquashFS images mate
            Only JFFS2 images can be converted this way
            Blade can be done this way .....Paul
            PAUL
            • skinterz
              • 89
              i give you my email for the 1x image you said you would send so cheers for that and just for my own curiosity i downloaded the convertor and changed the image to 1x .
              cheers
              <--skinterz added 5 Minutes and 58 Seconds later...-->
              can u use the ethernet connection or do i need null cable?..what the diff?
              cheers
              • plasterer
                • 1631
                Enthernet Connection is fine
                With this you need a rj45 enthernet crossover cable
                A straight cable will not work this way .....Paul
                PAUL
                • skinterz
                  • 89
                  cheers m8 just gonna order one of them now
                  • johnlogie
                    • 44
                    Get one from maplins for a fiver mate
                    • skinterz
                      • 89
                      yeah picked one up on ebay cheap as chips
                      • pete2vinal
                        • 6
                        can the v plus box be hacked? im getting tired of the dbox2 as it keeps failing
                        • BRIN_1307
                          • 30
                          nokia dbox2 has never failed on me why does yours what goes wrong and yes u can i think you have to do something with the card
                          IF U FIND THE INFORMATION USEFUL PRESS THE THANX BUTTON CHEERS!
                          • skinterz
                            • 89
                            paul you there mate?....i got the rj45 enthernet crossover cable, saved my image back up one partition ,flash without bootloader .
                            i read the FAQ and it says You can then connect via your FTP Program and save it to your PC. but when i connect to the pc and open up the prog im lost from there .do i have to put my isp login and password into the FTP program?
                            cheers .
                            • scubar
                              • 206
                              username = root
                              password = dbox2
                              depending on image
