Services & Bouquets
    Services & Bouquets
    Hi M8s
    I have a Nokia D-box2, I have flashed it now can some one explain how do I install channels via Ethernet cross over cable Services & Bouquets. I will appreciate your help and thanking you in advance.
  • MetMan
    • 1091
    Hi M8s
    try scanning and create ur own service file
    u need to set ur scan settings for ur area first though (location)
      Hi MetMan
      I know the scanning way it?s the Ethernet way I want to do it, because I knew a person moved to London and he used to flash the dbox2 and install Services via Ethernet cable in minutes and all the channels were lined up in order. Any hints or a bit of advice much appreciated thanks again for your time M8s.
      • MetMan
        • 1091
        Hi MetMan
        I know the scanning way it’s the Ethernet way I want to do it, because I knew a person moved to London and he used to flash the dbox2 and install Services via Ethernet cable in minutes and all the channels were lined up in order. Any hints or a bit of advice much appreciated thanks again for your time M8s.
        if u got a recent service.xml file for ur area and a bouquet.xml for ur area (and they will have to be very recent, lots of transponders switching frequencies. recently) then use xover ethernet (if direct connection pc to box) and ftp proggy and transfer to var/tuxbox/config/zapit folder, then reboot box or reload channels in service menu.
        if u ain't got those files then its a scan for service file (3 mins using fast scan)and bouquet editor to order ur channels or if using com11.3 or lhc2 img u can auto order by using v*m order setting.
          Hi MetMan
          Thanks just what I was looking for, a bit to let for me tonight I will try fiddling with it tomorrow thanks again.
