sagen d box
  • delr34
    • 6
    sagen d box
    hi guys can anyone help a flashed my d bow with commando image and rebooted it and it wont boot up help
  • jfish
    • 799
    i suspect you flashed a 2 chip version onto a 1 chip or vice-versa
    when you boot up , on the lcd screen does it say keine system
    you will need to use IFA to flash the correct image one, search for IFA on this forum
    • delr34
      • 6
      cheers for that a cant fine the IFA any ideas cheers del
        Seek and ye shall find. Hint! Downloads section
        • Tommo1973
          • 181
          Portable IFA
          Hi m8,
          You can try this version of portable IFA (thanks due to Renwich), only requires crossover cable to work and no install required!
          RapidShare: 1-CLICK Web hosting - Easy Filehosting
          Tommo
          • delr34
            • 6
            thanks guys ave got the ifa , crossover cable and commando 11.3 x1 but the ifa sees the boot requst then dose not do anythin eles cheers Del
            • delr34
              • 6
              well got it working again thanks guys for all ur help but am only getting the freeview channel can any 1 help with this thanks Del
              • MetMan
                • 1091
                do a search for magic files, that will help u
                • mini
                  • 602
                  copy all files from here and then extract them and place them into var/keys >>>>>http://www.mercs.us/tools/real_magic.rar
                  • delr34
                    • 6
                    hi m8 try that but still the same anythin else am missin am using commando 11.3 thanks Del
                    • DW190
                      You have a pm
                      • mickydibble
                        • 2166
                        did you read the included info read me file that comes with com 11.3?.....you need to chmod the attributes of some of the files to 755,namely the cams,and libcrypto once transfered over dbox side
