help needed flashed with ss-enigma and it sticks at start screen..cant flash ifa or ftp
ss-enigma
its an rs232 null modem cable you need check around....not sure about 25 pin ?? how many have they got dont use em...but they do usb to null....mComment
Because the box isn't working, it isn't communicating the network anyway so no either IP can be assigned to the box in the usual way or your box can't tell the network its there.
Just use a crossover cable and IFA. IFA uses ARP to assign an IP to your box through the MAC address (I think thats how it communicates anyway?).
Just make sure you have plenty of patience while the flashing is taking place, and then some....Comment
their 9 pin....u don't need it to use ifa as u don't need the ip address of the dbox.....ifa assigns its own...
ethernet cable (x over if direct) should do it on its own but some people seem to only have success with both cablesComment
An ethernet cable wont work, you need a crossover. You can use an ethernet if your going to run it through a router and then to your PCComment
PAUL
