ss-enigma
  • pilo
    • Sep 2009
    • 4
    ss-enigma
    help needed flashed with ss-enigma and it sticks at start screen..cant flash ifa or ftp
  • mickydibble
    • 2166
    Did you flash the wrong type of image ? 1 x or 2 x
    • plasterer
      • 1631
      Ifa will remove it no probs .................Paul
      PAUL
      • pilo
        • Sep 2009
        • 4
        no it was1x image for segam ...got ss-enigma v4 stuck on screen cant ftp or ifa as i dont know the image ip address
        • mickydibble
          • 2166
          you dont need ip with ifa....are you giving it time to flash
          • pilo
            • Sep 2009
            • 4
            cant ifa dont know the ip address of dbox now tried fta with eartenet cable think ill need toget null moden cable do you know what kind i need to get 25 pin on my pc 9 on dbox
            • mickydibble
              • 2166
              its an rs232 null modem cable you need check around....not sure about 25 pin ?? how many have they got dont use em...but they do usb to null....m
              • Noob
                • 25
                Because the box isn't working, it isn't communicating the network anyway so no either IP can be assigned to the box in the usual way or your box can't tell the network its there.
                Just use a crossover cable and IFA. IFA uses ARP to assign an IP to your box through the MAC address (I think thats how it communicates anyway?).
                Just make sure you have plenty of patience while the flashing is taking place, and then some....
                • MetMan
                  • 1091
                  their 9 pin....u don't need it to use ifa as u don't need the ip address of the dbox.....ifa assigns its own...
                  ethernet cable (x over if direct) should do it on its own but some people seem to only have success with both cables
                  • Noob
                    • 25
                    An ethernet cable wont work, you need a crossover. You can use an ethernet if your going to run it through a router and then to your PC
                    • PaphosAL
                      Old Git
                      • 1064
                      Use IFA Portable v3.1 - this flashes via ethernet cable only first time of trying, 99.9% of the time. Crossover patch cable is needed for connecting PC direct to dBox2, or std patch cable if connecting via a router.
                      Cheers- AL
                      • pilo
                        • Sep 2009
                        • 4
                        got it fixed thanks guys null modem cable first go
                        • PaphosAL
                          Old Git
                          • 1064
                          Quick! Make notes of exactly what you did while it's still fresh in your mind, then keep the notes somewhere very safe.
                          Coz in two weeks time, if similar happens again, you'll have clean forgotten...
