If you are still gettin a blank screen after a scan, try reflashing you box an than do a scan. Should pick up all channels again. You will however get "unknown provider" dnt worry. Complete the scan an you should have even more channels than you started with.
If scan is not working. reflash the image and than run a scan on 6952( 6952 is for my area. plz do so according to your area) , you should pik up abt 310 channels.
Reason: 6952 depending on area. please check your area.
Lost all channels at 11.30ish well it locked the screen and I dint notice till midnight. May be VM down was on 22DEC2009.
Scan but no transponders.
Will check in the morning. Mmm is this nagra3 as ive been told the box wont work in 2010 (
If you are finding no transponders
Either you have no signal,recheck your cables
Or your scanning on the wrong freaks,Recheck them
Plug in your subbed box while holding the up and down buttons
This will give you acsess to the Engineers menu
left and right to move through the pages,untill you find the freaks
Hope this helps .....................Paul
If your Happy with the Help push the Thanx button PAUL
My box bit the dust yesterday. No IP adress. \\\\\\\\\\\\error code set location blue>blue, then green>green? Trying to re-flash with some of the most mind boggling destructions I have ever read...Can some one help please.
Need more info to help further
The above dont make much sense.
Have a read and get back to us .................Paul
