new to dbox need help pls
  • MetMan
    • 1091
    #106
    Originally posted by mfitright
    ok thankyou and thankyou for helping me i have tried lots of things and i am getting desperate now kids moaning and i feel like pulling my hair out
    <--mfitright added 3 Minutes and 57 Seconds later...-->
    i have now pressed all buttons and booted up but when i go to scan i dont get options for uk just kabel deutchland can you recommend an image to try please
    well thats good what box is it? you can ftp to it? is it 1x 2x, what area r u have u got any files saved service bouquet etc or were they lost?
    • mfitright
      • 9
      #107
      hi it is a sagem dbox2 2 chip and i have not got any files all was lost i am in blackpool lancs
      • MetMan
        • 1091
        #108
        ok i've got a few imgs i could send u 1 if u want but u will have to rescan for ur area....if its a troublesome box picture freezing i'll send u an img with the gbox emu seems to be better with problem boxes but gbox won't au but all u have to do is switch to evocamd let it au and switch back.....i've sent u a pm reply to that and send me ur email addy and i'll send u an img....
        • mfitright
          • 9
          #109
          i have replied to pm thankyou so much for your help
          • plasterer
            • 1631
            #110
            Remove the E Mail Addy
            For your own saftey mate ....Paul
            PAUL
            • brianbri
              • Aug 2008
              • 4
              #111
              all the good advice on this thread alone has enabled me to flash my image to Blade. Had a few sticky moments could not get IFA to work so used flashFXP and flashed through Dbox. Scared to press the button (do you want to flash image) first time .. Easy when you know how and when things go well.
              Thanks guys
              • kawasakikr1
                • 8
                #112
                Hi, sorry to butt in on this thread but i'm also in the Blackpool area. When I set my area on the Dbox Blackpool isn't listed, the nearest 2 are Preston and Liverpool. Could anyone tell me which it should be set to, or does it not matter which?
                • plasterer
                  • 1631
                  #113
                  Just try both
                  And the one with the most stick with that one ............Paul
                  PAUL
                  • gizmo.1484
                    • 873
                    #114
                    Originally posted by kawasakikr1
                    Hi, sorry to butt in on this thread but I'm also in the Blackpool area. When I set my area on the Dbox Blackpool isn't listed, the nearest 2 are Preston and Liverpool. Could anyone tell me which it should be set to, or does it not matter which?
                    If your area is not listed then have a look to see if your county is listed and press that as i had to do the same thing as my area would not let me scan hope this helps m8....
