this is how I remove unwanted channels then even after rescan no unwanted channels (if you want channels back just delete myservices file)
Backup your services file on your pc. Make a copy of services.xml to myservices.xml. In 'myservices.xml' edit the lines with the adult channel entries to include 'action=remove'
For example if a line reads:
channel service_id="01fd" name="Red Hot Ladies" service_type="01"
change it to:
channel service_id="01fd" action="remove" name="Red Hot Ladies" service_type="01"
When you've changed all relevent entries (there may be several for each channel depending on the stream info), copy the 'myservices.xml' file across to the same directory the 'services.xml' file currently resides in. Restart your box and ~~~~ be gone!!
This method is slightly more complicated than simply removing the entries from services.xml, but does have the advantage that the autoscan of channels can be left on
to stop adult channels takes a bit of time but once done
if you save your zapit file on your pc with the services and edited myservices files you can ftp them to any image
you have this is what i do (if you want no adult leave my services in if not delete the mysevices file)
hope this may help
change it to:
hope this may help
, but seriously they save the best post till the last,must remember this way.
respect al
