gbox swap function
  • Nazim123
    • 29
    gbox swap function
    hello, can anone please tell sagem) me any images that have the gbox swap as my dbox has the mouse crash. (chriping sage) thanks
  • dboxdaz
    • 22
    blade quad m8.
    • plasterer
      • 1631
      Andromeda and Blade have G box swop
      Thanx to xenafan Top images both ................Paul
      PAUL
      • Nazim123
        • 29
        thanks, but have you got a download link for these images at all
        • plasterer
          • 1631
          Try pushing the Downloads button at the top of the page
          Or the search button ,Thats wot there up there for ...Paul
          PAUL
          • Nazim123
            • 29
            thanks, yeah ive tried the quad one but when i converted it was kind of different and kein systems my box can you please give me a link to the Andromeda image and how to turn on the funtion so my dbox stops stuttering and crash
            • plasterer
              • 1631
              Cant use external links on the forum mate
              Just select G box and copy Evo to Gbox ....Thats it .....Paul
              Is it 1 x or 2 x your after
              PAUL
              • Nazim123
                • 29
                im after a 1x, the blade quad which i converted did not come out right, no spaces between words, pink screen really messy i was wondering if anyone could upload the Andromeda and tell me how to make it stop my stuttering dbox
                • MetMan
                  • 1091
                  LHC2 has this feature, u will need to covert to 1x first....remember choose "convert 1x NO BOOTLOADER"
                  once flashed on press blue
                  blue
                  then yellow with evocamd or mgcamd active and u will need to reboot.
                  also u will need the gbox cam and camd2 in the /vbar/bin/emu folder (chmod 755)
                  and the gbox_cfg file in the /var/key folder
                  cheers
                  • Nazim123
                    • 29
                    metman thanks very much for your advice, ive loaded the image and done a service scan and nothing seems to be working not even the standard tv channels, all connections are fine however flash fxp will not let me transfer any most of the magic files and even when i 755 them then dont save, it keeps saying files transfer failed !!! ive had this problem now for 3 days any help PLEASE !!!
                    • Fergal
                      • Aug 2008
                      • 1007
                      Got a feeling of da ja vu here
                      can you ftp to the /tmp folder if you can flash it again then before you transfer any file to the box see if it will let you transfer a file from the box to your pc
                      1 step at a time!
                      • Nazim123
                        • 29
                        VERGAL !!! hi, i can flash to the temp however i flashed it like 4 times now and someitmes it will let me copy everything to teh key folder but nothing to the bin emu folder !!!
                        • Fergal
                          • Aug 2008
                          • 1007
                          The camd on this image goes in var/bin/emu not bin/emu
                          flash it again then go to var/bin/emu then in flashfxp browse to were you have evocamd on your pc and right click on evocamd only and choose transfer after it has gone in right click on it and choose chmodd/attributes and change the valu to 755
                          • Nazim123
                            • 29
                            sprru vergal i meant it is in var bin emu however when i 755 it and i connect it and i click on attributes the boxes are not ticked anymore and cna you please tell me what files i have to copy and where to, cheers
                            • Tommo1973
                              • 181
                              Me to m8, it would seem there are a few of these dodgy mouse like sagems around as I have seen a similar post over on ukcvs (posted by imran123).
                              Tommo
