Unable to flash DBox 2
  • tpanes
    • Aug 2008
    I seem to have a problem flashing a DBox2. It has worked once before, but the image somehow got corrupted when doing a scan.
    I am using 'DBOX2 Image Flash assistant' to do this and the image i am dowloading is Andromeda V2 Final Version).
    On the console, the box goes to the dbox2-ppcboot> and goes no futher.
    Is there a problem with box?
    Can somebody give me an indication of what to do
  • Jaffa
    • 1612
    I am not up to speed to much with IFA but have you tried a different version of it, some peple experience problems with certain versions but other version work.
    Alternatively have you tried to ftp the image and update it woth your remote control, I always thought it was the easiest and best way to do it.
    • toto67
      • Feb 2008
      • 178
      Sometimes you need to do it a good few times m8..I had one that must have took bout 20 x's and I aint kidding..Maybe your timing of when you put the power cable/plug in isnt quick enough but just try it again m8
      • tpanes
        • Aug 2008
        Can't ftp or do anything else. The other boxes I have work fine. There seems a problem with ths box
        • Fergal
          • Aug 2008
          • 1007
          On this command type boot net and press enter if it dont work post the full log
          dbox2-ppcboot>boot net
