nokia dbox pacino3 image
  • mazzer110
    • Feb 2010
    Originally posted by mickydibble
    get the latest commando image 11.3/12 flash this..... then you need the correct files ie magic files and ftp these to the same named folders on box chmod the cams in var/emu save and then on box set location and scan....
    but you should get fta channels before moving on,after img is installed if you have a live feed from vm then you should get fta channels if not it is a sygnal prob like already mentioned micky
    Thanks for this. Exactly what I needed. It works now.
    • bob114
      • 192
      #17
      hi
      from post 15
      don't quite know what I was doing wrong before but that doesn't matter now - followed your suggestion and instructions and dbox up and running. thanks for advice, and the knowledge. Great site, great help cheers
      now back up your working image and save to pc
      • mickydibble
        • 2166
        #18
        No problem. Hit the thnx. Button
