sagem dbox
  • mickyboy
    • 524
    sagem dbox
    ok ive followed aftermaths instructions on how to do dbox and when connecting dbox to computer via null cable i get this below ,,, anybody help oot
    Kernel command line: root=/dev/mtdblock2 rw console=ttyS0
    Decrementer Frequency = 247500000/60
    m8xx_wdt: active wdt found (SWTC: 0xFFFF, SWP: 0x1)
    m8xx_wdt: keep-alive trigger installed (PITC: 0x2000)
    Console: colour dummy device 80x25
    Calibrating delay loop... 65.74 BogoMIPS
    Memory: 30888k available (1052k kernel code, 368k data, 60k init, 0k highmem)
    Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
    Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
    Mount cache hash table entries: 512 (or
    Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
    Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
    POSIX conformance testing by UNIFIX
    Linux NET4.0 for Linux 2.4
    Based upon Swansea University Computer Society NET3.039
    Initializing RT netlink socket
    Starting kswapd
    devfs: v1.12c (20020818) Richard Gooch ([email protected])
    devfs: boot_options: 0x1
    JFFS2 version 2.2. (C) 2001-2003 Red Hat, Inc.
    i2c-core.o: i2c core module version 2.6.1 (20010830)
    i2c-dev.o: i2c /dev entries driver module ve
    CPM UART driver version 0.04
    ttyS0 at 0x0280 is on SMC1 using BRGttyS1 at 0x0380 is on SMC2 using BRG2
    pty: 256 Unix98 ptys configured
    eth0: CPM ENET Version 0.2.dbox2 on SCC2, 00:50:9c:3d:a0:08
    D-Box 2 flash driver (size->0x800000 mem->0x10000000)
    CFI: Found no D-Box 2 flash memory device at location zero
    D-Box 2 flash memory: Found 1 x16 devices at 0x0 in 16-bit mode
    Intel/Sharp Extended Query Table at 0x0031
    cfi_cmdset_0001: Erase suspend on write enabled
    Using buffer write method
    Creating 5 MTD partitions o
    0x00000000-0x00020000 : "BR bootloader"
    0x00020000-0x00040000 : "flfs (u-boot)"
    0x00040000-0x00800000 : "root (jffs2)"
    0x00020000-0x00800000 : "flash without bootloader"
    0x00000000-0x00800000 : "complete flash"
    Linux video capture interface: v1.00
    mice: PS/2 mouse device common for all mice
    NET4: Linux TCP/IP 1.0 for NET4.0
    IP Protocols: ICMP, UDP, TCP
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP: Hash tables configured (established 2048 bind 4096)
    NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    cramfs: wrong magic
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000238: 0x1000 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000002a4: 0x0040 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000049c: 0x1000 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000538: 0x4000 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000630: 0x4000 in
    stead
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000068c: 0x0040 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000007c0: 0x0001 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000009dc: 0x0001 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000a28: 0x0400 in
    stead
    Further such events for this erase block will not be printed
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020000: 0x4000 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020004: 0x0010 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002000c: 0x0004 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020024: 0x0040 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002002c: 0x0040 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002004c: 0x0040 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020050: 0x4000 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020058: 0x4000 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020064: 0x0040 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002008c: 0x0004 in
    stead
    VFS: Mounted root (jffs2 filesystem).
    Mounted devfs on /dev
    Freeing unused kernel memory: 60k init
    Starting pid 11, console /dev/console: '/etc/init.d/rcS'ti-call b
    Chip reports voltage low
    Erase at 0x00000000 failed immediately: errno -5
    Using /lib/modules/2.4.31-dbox2/misc/event.o
    event: $Id: event.c,v 1.12 2003/09/30 05:45:38 obi Exp $
    Using /lib/modules/2.4.31-dbox2/misc/tuxbox.o
    Using /lib/modules/2.4.31-dbox2/misc/dvb-core.o
    Chip reports voltage low on erase: status 0xa8
    Erase at 0x00020000 failed immediately: errno -5
    Using /lib/modules/2.4.31-dbox2/misc/dbox2_i2c.o
    [i2c-8xx]: mpc 8xx i2c init
    [i2c-8xx]: adapter: 0
    Using /lib/modules/2.4.31-dbox2/misc/dbox2_fp.o
    ?debug: DDF: Calibrating delay loop... debug: DDF: 66.76 BogoMIPS
    debug: LCD init error -1
    debug: BMon V1.2 mID 03
    debug: feID 00 enxID 03
    debug: fpID 52 dsID 01-1d.a8.09.08.00.00-97
    debug: HWrev 61 FPrev 0.23
    debug: B/Ex/Fl(MB) 32/00/08
    WATCHDOG reset enabled
    dbox2:root> debug:
    BOOTP/TFTP bootstrap loader (v0.3)
    debug:
    debug: Transmitting BOOTP request via broadcast
    debug: Given up BOOTP/TFTP boot
    boot net failed
    Flash-FS bootstrap loader (v1.5)
    Found Flash-FS superblock version 3.1
    Found file /root/platform/sagem-dbox2/kernel/os in Flash-FS
    debug: Got Block #0040
    will verify ELF image, start= 0x800000, size= 152952
    verify sig: 263
    Branching to 0x40000
    U-Boot 1.1.2 (TuxBox) (May 23 2004 - 21:44:01)
    CPU: PPC823ZTnnB2 at 66 MHz: 2 kB I-Cache 1 kB D-Cache
    Board: DBOX2, Sagem, BMon V1.2
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    Scanning JFFS2 FS: ....... done.
    FB: ready
    LCD: ready
    In: serial
    Out: serial
    Err: serial
    Net: SCC ETHERNET
    Options:
    1: Console on nul
    2: Console on ttyS0
    3: Console on framebuffer
    Select option (1-3), other keys to stop autoboot: 0
    Un-Protected 63 sectors
    ### FS (jffs2) loading 'vmlinuz' to 0x100000
    ### FS load complete: 619057 bytes loaded to 0x100000
    ## Booting image at 00100000 ...
    Image Name: dbox2
    Image Type: PowerPC Linux Kernel Image (gzip compressed)
    Data Size: 618993 Bytes = 604.5 kB
    Load Address: 00000000
    Entry Point: 00000000
    Verifying Check
    Uncompressing Kernel Image ... OK
    Linux version 2.4.31-dbox2 (sportster@bar-wsl01) (gcc version 3.3.5) #21 So Jun
    19 18:44:54 CEST 2005
    On node 0 totalpages: 8192
    zone(0): 8192 pages.
    zone(1): 0 pages.
    zone(2): 0 pages.
    Mount cache hash table entries: 512 (order: 0, 4096 bytes)
    Initializing RT n
    Starting kswapd
    i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
    Creating 5 MTD partitions on "D-Box 2 flash memory":
    cramfs: wrong magic
    stead
    stead
    stead
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000668: 0x0004 in
    stead
    stead
    stead
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000af8: 0x0400 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000ffc: 0x0400 in
    stead
    stead
    stead
    stead
    Sel
    steadtion
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000200c8: 0x4000 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000200dc: 0x0040 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000200f0: 0x0001 ininux Kernel Image (gzip compressed)
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000200f8: 0x1000 in
    Entry Point
    Mounted devfs on /devages.
    zone(2): 0 pages.
    Ke
    Decrementer Freque
    Console: colou
    event: $Id: event.c,v 1.12 2003/09/30 05:45:38 obi Exp $librating delay loop... 65.74
    Buffer cach
    [i2c-8xx]: adapter: 01024 (order: 0, 4096
    Linux NET4.0 for L
    Based upon Swa
    debug: feID 00 enxID 03ciety NET3.039
    Initializing RT n
    debug: Transmitting BOOTP request via broadcastle version 2.6.1 (20010830)
    boot net failedion 2.6.1 (2001
    ttyS0 at 0x02
    debug: Got Block #0040 Unix98 ptys configure
    will verify ELF image, start= 0x800000, size= 152952n 0.2.dbox2 on SCC2, 00:50:9c:3d:a0:08
    verify sig: 263
    Branching to 0x400002 flash driver (size
    I2C: ready
    I
    DRAM: 32 MBtended Query
    FLASH: 8 MB031
    FB: readybled
    LCD: ready
    In: serial
    Using buffer
    Out: serial
    Err: serialeating 5 MTD
    Net: SCC ETHERNET 2 flash memory":
    Options:
    1: Console on null
    0x000000
    2: Console on ttyS0otloader"
    3: Console on framebuffer0x00020000-0x00040000 : "fl
    Select option (1-3), other keys to stop autoboot: 0x00040000-0x00800000 : "root (jffs2)"
    .................................................. .............ootloader"
    0x
    Un-Protected 63 sectorsomplete flash"
    Verifying Checksum ... OK0.
    Uncompressing Kernel Image ... OKng magic
    jffs2_sc
    stead
    19 18:44:54 CEST 2005lock(): Magic bitmask
    On node 0 totalpages: 819202a4: 0x0040 in
    zone(1): 0 pages.
    stead
    zone(2): 0 pages.
    stead
    jffs2_scan_era
    Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)0 in
    Inode cache hash table entries: 2048 (order: 2, 16384 bytes)agic bitmask 0x1985 not found at 0x00000538: 0x4000 in
    Further
    Initializing RT netlink socketc bitmask 0x1985 not found at
    Starting kswapd00 in
    stead
    devfs: boot_options: 0x1004: 0x0410 in
    stead
    jffs2_scan_
    i2c-core.o: i2c core module version 2.6.1 (20010830)2000c: 0x0004 in
    i2c-dev.o: i2c /dev entries driver module vestead
    CFI: Found no D-Box 2 flash memory device at location zeroask 0x1985 not found at 0x0002002c: 0x0040 in
    stead
    cfi_cmdset_0001: Erase suspend on write enablederaseblock(): Magic bitmask 0x1985 not found at
    Linux video capture interface: v1.000k init
    mice: PS/2 mouse device common for all miceole: '/etc/init.d/rcS'ti-call b
    Chip reports
    IP Protocols: ICMP, UDP, TCP0xa8
    IP: routing cache hash table of 512 buckets, 4Kbytesediately: errno -5
    TCP: Hash tables configured (established 2048 bind 4096).o
    event: $I
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000630: 0x4000 in0020000 failed immediately: errno -5
    steadsing
    [i2c-8xx]: adap
    stead
    stead6 Bog
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000af8: 0x0400 in init error -1
    stead
    deb
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00 dsID 01-1d.a8.09.08
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00002db0: 0x1000 int net failed
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00003748: 0x0400 inund file /root/platform/sagem-dbox2/kernel/os in Flash-FS
    stead
    stead2
    stead2
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000201ec: 0x0040 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000201f4: 0x4000 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020218: 0x0400 in
    stead
  • mtv1
    The Stig PT
    • 4413
    so what you need a working image you could have just asked
    • mickyboy
      • 524
      if you say so m8 a dont know anything about em
      • Fergal
        • Aug 2008
        • 1007
        Have you actually flashed a image onto it using this
        • burnsy69
          • Mar 2010
          is there any other way to install new image rather than through hyper terminal?
          • MetMan
            • 1091
            ftp or ifa using network cable.......
