faulty tuner?? or did i do it wrong
  • axpk95
    • May 2010
    • 5
    im trying to fix a friends sagem dbox2 (meh i have eurovox )
    anyway i put commando 12 x1 image on it and also the update , added magic files chmod the ones i needed to do
    select location did fast scan ..... picked up 307 transponders no channels found
    brute force scan ..... picked up 307 transponders no channels found
    hmmmmm so i thought i'll try something else so i flashed it with umm ultraphat apocalypse added magic files chmod etc the ones i needed to do
    select location did fast scan ..... picked up 376 transponders no channels found
    brute force scan ..... picked up 376 transponders no channels found
    sooo am i missing something here or is it broken
    oh and signal is good my eurovox is running fine
  • chris31560
    • Feb 2010
    • 912
    check the tuner m8, red button then blue button shows u the ber/sig/snr..
    A LITTLE THANX GOES A LONG WAY
    • plasterer
      • 1631
      As the box ever worked
      Run boot manager with a null and post resullts here in a tx doc
      Will tell if your tuners goofed or not ..........Paul
      PAUL
      • axpk95
        • May 2010
        • 5
        thanks i got this on screen
        ber max = 262143
        ber min = 100000
        snr max = 30561
        snr min = 22136
        sig max = 65535
        sig min = 65535
        birtate is all 0
        ok so i guess the blue line in the middle
        snr max = 30561 is a little low so i squashed the aerial connector on the dbox so it was very tight fit
        now its at
        snr max = 64708
        snr min = 64708
        sig max = 61984
        sig min = 61984
        all colours are now at the top of the chart
        ......... bruteforce scan transponder scan failed
        wtf
        • axpk95
          • May 2010
          • 5
          ok i got it all heres the text file thanks
          • plasterer
            • 1631
            Tuner dosent seem to be registering correctly mate
            It should read
            DVB: registering frontend 0:0 (VES1820 based DVB-C frontend)...
            so may be faulty or unseated ........Paul
            PAUL
            • axpk95
              • May 2010
              • 5
              It should read
              i see thanks
              so i'll take a look see if anythin obvious sticks out cheers
              • Elric
                V.I.P. soft lad
                • 853
                you could try takin out any splitters on the feed and tryin
                direct to the feed
