need help....dbox2 u-boot
  • skegsagypsy
    • Aug 2009
    • 1230
    Reflashed my dbox2(didn't realise the dog had knocked the cable out) scanned and got all channels, ftp'd the rom files, rebooted and the box hangs on boot screen, lcd shows u-boot, Ive tried reflashing with various ifa proggies but to no avail, I know thier nearing the end but I'd like to squeeze the last drop out of my faithful dbox2 , any ideas guys on how I should proceed ?
    'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
    -Bishop Desmond Tutu
  • gage666
    • Jul 2010
    i have the same problem
    • Fergal
      • Aug 2008
      • 1007
      Try portable IFA its in the downloads.
      • skegsagypsy
        • Aug 2009
        • 1230
        I did try portable IFA , any other suggestions ?
        • ManofScience
          • 650
          try it again. it works 99% of the time if you're flashing with the correct image.
          • skegsagypsy
            • Aug 2009
            • 1230
            M8, I've tried it a load of times, I've been flashing dbox2's for yrs, never had this issue IFA will not flash an image to the box regardless of which version I have tried
            • Fergal
              • Aug 2008
              • 1007
              Have you set your nic to 10base_T halfduplex and give it a static ip of 192.168.1.201
              sub 255.255.255.0
              also if you have a nullmodem cable use that along side you ethernet crossover cable and disable any antivirus,firewalls and any other nic's including wireless
              if that dont work flash using the nullmodem cable only method.
              • ManofScience
                • 650
                well, explain the error more - is it not connecting? or it is connnecting but fails hald way thru? or it flashes ok but it 'kein system' on the LCD?
                • skegsagypsy
                  • Aug 2009
                  • 1230
                  It was connecting to the dbox, but timing out, in other words not flashing the image ! I have now succesfully got an image on the box, I used Hyperterminal to add U-boot.mot and then flashed with IFA, scanning now as I type but not finding any channels at the minute
                  • ManofScience
                    • 650
                    does the scan stop straight away or after some minutes? which image is on it? did you 'set your location' via the blue button before scanning?
                    • skegsagypsy
                      • Aug 2009
                      • 1230
                      It's scanning but not finding any transponders, blade x2 image, set location, signals fine, I'm at a loss
                      • skegsagypsy
                        • Aug 2009
                        • 1230
                        All up and running again, god only knows how though
