IMAGE FLASH ASISTANT
  • lannyb2000
    • 38
    HI
    DOSE ANY 1 NO WERE TO GET IFA IN ENGLISH,GOT A NOKIA D BOX 2 OF A FRIEND HE SAID IT WAS COMEING UP WAITING FOR TIME,SO I PLUGGED IT IN TO TV COULD NOT GET INTO ANY MENUS OR ANY THING JUST ZILCH,I KNOW THEIR IS POWER THEIR BECAUSE WHEN YOU USE THE REMOTE THE LIGHT ON THE BOX FLASHES,ANY HOW WE DID A RE FLASH BUT THIS CAME UP ON IFA
    Achtung: RSH ist bei fast allen Linux-Images nicht konfiguriert/aktiviert!
    *** RSH wird also nur funktionieren, falls ihr euren Linux-Kernel gepatcht habt.
    ANY 1 SPEEK GERMAN TO TRANSLATE OR CAN I DOWNLOAD THE ENGLISH VERSION OF THIS SOFTWARE,JUST WONDERING IF THIS BOX IS BUGGERED,THE LCD SCREEN ON THE BOX DOSE NOT WORK SO I CAN NOT SEE WHAT IT SAYS WHEN TRYING TO FLASH
    SINCE FOUND OUT IT MEANS
    Note: RSH is not with nearly all Linux images configured/activated! *** RSH will thus only function, if it your Linux Kernel gepatcht.
    were do i get this from and how do i put it on the box,can not use ftp because their is no ip adress on the box
    any advice would be grateful for
    vince
  • DW190
    Make sure you select English
    Any problems there are more here:
    • lannyb2000
      • 38
      cheers for that
      but i am a bit lost on this 1,when i click the link what do i down load u code checker already got ifa,can you tell me what this message means,is the box dead ,no image on it,flashed boxs before no problem,is their any guides to walk you through it or should i just bin the d box
      • bob114
        • 192
        hi
        Warning: RSH is in almost all Linux images is not configured / activated!
        *** RSH will therefore only work if you have your Linux kernel have patched.
        thats it translated not sure what it all means
        • nickoskip
          • 4
          Originally posted by bob114
          hi
          i need ucode.bin any help
