hi can any one tell me if you can enter the codes manually on this box if so how do you do it
ddigital box updates
Only way i know to enter a code is to press menu and then begin entering numbers immediately, only problem is i dont know ant telewest codes -
Hit the blue button
Go to tuxbox commander
navigate to keys folder
then with your cursor over the keylist.txt file hit number 4
Hit home when you're done with changing the keys
then yes to save file
Hope this works!
P.S you will need to reset your ROM after entering the new keysComment
I have a DDigital box and he remote has no blue button! ive been through all the options and cant find tuxbox. any more ideas? thanks anywayHit the blue button
Hope this works!
Here's the link, download and run:
Ive found some codes but dont know how to enter them into the box. Ive got to the setup screen as described and then into Nagravision, but the codes in there dont seem to match the format of the codes ive downloaded.
I guess my question is how do you actually input the codes?
ThanksComment
DDigital
guys
It is simple!
1- download the software winRAR, the evaluation copy, save it where you can remember it! and run it
2- download the keys on this site
3-use WinRAR, to open the file, now you can see the new key combinations, write them down.
4- follow the steps to get to the key change area
5- don't change any settings along the way
6 - insert the new keys and save it after each change
7 - job done! iv'e only been on this site for 1 hour - job done
cheers guysLast edited by gurshwin; 30 November, 2008, 21:45.Comment
