Cabbaged box i think
  • HIGH_MAINTENANCE
    • 5
    hi all,
    Tried to reflash my Dbox it currently has Blade on it when it starts to boot up it just cuts out and reboots again so i thought i would reflash it. Anybody know what the below means.
    ?debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
    debug: BMon V1.0 mID 01
    debug: feID 7a gtxID 0b
    debug: fpID 5a dsID Hallenberg.com
    debug: HWrev X5 SWrev 0.81
    debug: B/Ex/Fl(MB) 32/00/08
    WATCHDOG reset enabled
    debug: autoboot aborted from terminal
    dbox2:root> boot net net net net net net net net net net
    debug:
    BOOTP/TFTP bootstrap loader (v0.3)
    debug:
    debug: Transmitting BOOTP request via broadcast
    debug: Given up BOOTP/TFTP boot
    boot net failed
    debug:
    debug:
    debug: Got BOOTP reply from Server IP 192.168.0.2, My IP This my ip number here
    debug: Sending TFTP-request for file u-boot
    will verify ELF image, start= 0x800000, size= 140064
    verify sig: 262
    boot net: boot file has no valid signature
    Branching to 0x40000
    U-Boot 1.3.1 (Tuxbox - Hallenberg.com) (Dec 23 2007 - 22:22:21)
    CPU: PPC823ZTnnA at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache
    *** Warning: CPU Core has Silicon Bugs -- Check the Errata ***
    Board: DBOX2, Nokia, BMon V1.0
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    LCD: ready
    In: serial
    Out: serial
    Err: serial
    Net: SCC ETHERNET
    BOOTP broadcast 1
    Using SCC ETHERNET device
    TFTP from server 192.168.-.-; our IP address is 192.168.0.---
    Filename 'u-boot'.
    Load address: 0x100000
    Loading: Using SCC ETHERNET device
    TFTP from server 192.168.0.2; our IP address is 192.168.0.---
    Filename 'logo-lcd'.
    Loading: ##
    done
    Bytes transferred = 7680 (1e00 hex)
    BOOTP broadcast 1
    TFTP from server 192.168.0.-; our IP address is 192.168.0.---
    Filename 'u-boot'.
    Filename 'logo-fb'.
    Loading: ####
    done
    Bytes transferred = 15684 (3d44 hex)
    Options:
    1: Console on null
    2: Console on ttyS0
    3: Console on framebuffer
    Select option (1-3), other keys to stop autoboot: 0
    Filename 'kernel-cdk'.
    Loading: ################################################## ###############
    done
    Bytes transferred = 626108 (98dbc hex)
    Filename 'u-initrd'.
    Load address: 0x400000
    done
    Bytes transferred = 579075 (8d603 hex)
    .................................................. ............. done
    Un-Protected 63 sectors
    ## Booting image at 00100000 ...
    Image Name: dbox2
    Image Type: PowerPC Linux Kernel Image (gzip compressed)
    Data Size: 626044 Bytes = 611.4 kB
    Load Address: 00000000
    Entry Point: 00000000
    Verifying Checksum ... OK
    Uncompressing Kernel Image ... OK
    ## Loading RAMDisk Image at 00400000 ...
    Image Name: Ramdisk Image
    Image Type: PowerPC Linux RAMDisk Image (gzip compressed)
    Data Size: 579011 Bytes = 565.4 kB
    Loading Ramdisk to 01f21000, end 01fae5c3 ... OK
    Linux version 2.4.36-dbox2 (Hallenberg.com) (gcc version 3.4.6) #2 So 6. Jan 18:22:41 CET 2008
    On node 0 totalpages: 8192
    zone(0): 8192 pages.
    zone(1): 0 pages.
    zone(2): 0 pages.
    Kernel command line: console=ttyS0 root=/dev/ram rw ip=192.168.0.202:192.168.0.2::::ff
    Decrementer Frequency = 252000000/60
    m8xx_wdt: active wdt found (SWTC: 0xFFFF, SWP: 0x1)
    m8xx_wdt: keep-alive trigger installed (PITC: 0x12C0)
    Console: colour dummy device 80x25
    Calibrating delay loop... 66.96 BogoMIPS
    Memory: 30356k available (1048k kernel code, 324k data, 72k init, 0k highmem)
    Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
    Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
    Mount cache hash table entries: 512 (order: 0, 4096 bytes)
    Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
    Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
    POSIX conformance testing by UNIFIX
    Linux NET4.0 for Linux 2.4
    Based upon Swansea University Computer Society NET3.039
    Initializing RT netlink socket
    Starting kswapd
    devfs: v1.12c (20020818) Richard Gooch ([email protected])
    devfs: boot_options: 0x1
    i2c-core.o: i2c core module version 2.6.1 (20010830)
    i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
    CPM UART driver version 0.04
    ttyS0 at 0x0280 is on SMC1 using BRG?ttyS1 at 0x0380 is on SMC2 using BRG2
    pty: 256 Unix98 ptys configured
    eth0: CPM ENET Version 0.2.dbox2 on SCC2, 00:50:9c:1a:b4:57
    RAMDISK driver initialized: 16 RAM disks of 3333K size 1024 blocksize
    D-Box 2 flash driver (size->0x800000 mem->0x10000000)
    D-Box 2 flash memory: Found 2 x16 devices at 0x0 in 32-bit bank
    Amd/Fujitsu Extended Query Table at 0x0040
    number of CFI chips: 1
    cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
    Creating 6 MTD partitions on "D-Box 2 flash memory":
    0x00000000-0x00020000 : "BR bootloader"
    0x00020000-0x00040000 : "FLFS (U-Boot)"
    0x00040000-0x006a0000 : "root (rootfs)"
    0x006a0000-0x00800000 : "var (jffs2)"
    0x00020000-0x00800000 : "Flash without bootloader"
    0x00000000-0x00800000 : "Complete Flash"
    Linux video capture interface: v1.00
    mice: PS/2 mouse device common for all mice
    NET4: Linux TCP/IP 1.0 for NET4.0
    IP Protocols: ICMP, UDP, TCP
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP: Hash tables configured (established 2048 bind 4096)
    IP-Config: Guessing netmask 255.255.255.0
    IP-Config: Complete:
    device=eth0, addr=192.168.0.202, mask=255.255.255.0, gw=255.255.255.255,
    host=192.168.0.202, domain=, nis-domain=(none),
    bootserver=192.168.0.2, rootserver=192.168.0.-, rootpath=
    NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    RAMDISK: Compressed image found at block 0
    Freeing initrd memory: 565k freed
    VFS: Mounted root (ext2 filesystem).
    Mounted devfs on /dev
    Freeing unused kernel memory: 72k init
    Bad emulation init/1
    NIP: 0fedce50 instruction: 7df802a6 opcode: 1f A: 18 B: 0 C: a code: 153 rc: 0
    pte @ 0x fedce50: (0xc1fa80fc)->(0xc1f3db70)->0x01bc1889
    RPN: 01bc1 PP: 2 SPS: 1 SH: 0 CI: 0 v: 1
    Kernel VA for NIP 0xc1bc1e50 pte @ 0xc1bc1e50: no pmd
    Obviously i amaended the ip so its not that.
    Any ideas, is my box dead now and just good as a paper weight.
    Thanks in advance
  • DiddyDave
    • 213
    Make sure that the image is not broken from the download then make sure that you are flashing with the right version of the image
    X1 or X2
    As it does seem to be trying to flash your box
    Sorry double post need to remove this one please
    • DiddyDave
      • 213
      X1 or X2 Dbox2 Chip
      • HIGH_MAINTENANCE
        • 5
        its definatley a X2 i aint got a clue it begins to load and flash then just sticks, thanks for replying diddy
