Channels stopped!
Save your bouquets file and services to your pc using ftp, then put the new image into tmp folder (make sure you have the correct one, either 1x or 2x)
To flash an image, go into:
dbox
service
image upgrade
Flash One partition
Flash WITHOUT Bootloader
Make sure you select flash without bootloader mate.
Also if you want more than FTA, you'll need a full image, which you should be able to find on the chatterbox toolbar. Hope this helps
The Falkirk Wheel...... It's the best we can do!Comment
tried this but is still boots with the sportster on start up and all channels FTA. All i did last night was disconnect the box from the mains and relocated in the room. Then that was it all channels goneSave your bouquets file and services to your pc using ftp, then put the new image into tmp folder (make sure you have the correct one, either 1x or 2x)
dbox
service
image upgrade
Flash One partition
When you say if I want more than FTA then i will need the FULL IMAGE - Well I did have all the channels until i disconnected the box from mains for 5 minutes and then they all went. I do not understand it. I have tried tranferring all the NEw Fix files into VAR/KEYS and rebooted and still nothing.Comment
Something definelty going on.
Anyway i am left with a dead box as while i was reflashing the power cut for a couple of seconds and now nothing on the box when i turn on. Cannot go into the DBOX service menu or anything like that.
any ideas?. or is the box ready for the bin now??Comment
You will need to reflash the box with a program called IFA.Something definelty going on.
any ideas?. or is the box ready for the bin now??sigpicComment
If you had a power cut whilst flashing then the only way now is to use IFA image flashing assistant, you will need a cross over ethernet cable and ideally a null modem cable, you will then be able to flash your box again.Something definelty going on.
DerekComment
Thanks for that i have IFA on my PC. Any ideas where i can get a good working image from?? Any links?....I had Sportster on it before
Also i thought I would only need a NULL MODEM CABLE to use IFA. ??..
Also it looks like the keys been rolled getting alot of calls.
thanksComment
Ok i have tried this and the IFA screen just reads "WAITING FOR DBOX START" when the flashing is started. It looks like it is not recognising that the DBOX is on.........need some help on this.
IS the Waiting for Dbox to stat normal?Last edited by punjabi boy; 4 December, 2008, 12:12.Comment
Plug the box in after you see that message.Comment
