sportster image
  • angrycat
    • 165
    #16
    flash image
    I've got Sportster image installed with the latest update.
    I dont understand m8, what keys folder & services, bouquet files do you mean ?
    • Jaffa
      • 1612
      #17
      If you ftp to the dbox and go to /var/keys then thats the folder you need to ftp to your pc for safe keeping.
      Then you go to /var/tuxbox/config/zapit and you will see the service and bouquets files there, ftp to your pc aswell for safe keeping, then when you put on new image you put those safe files back again and evrything should work.
      • angrycat
        • 165
        #18
        flash image
        Ta jaffa, i'm thinkin of tryin the new Layky image, so if somethin goes wrong
        i'll be able to get back my first image
        • sherm
          • 4
          #19
          commando 10 is the best m8
          • Jaffa
            • 1612
            #20
            As long as you backed it up then you will be able to try any image, I try almost every image released but I havent tried Commando 10 yet, havent had the time.
            • roblowe91
              #21
              hi,what is ftp i'm new to this aswell
              cheers
              • Derekwd
                • 244
                #22
                File transfer protocol, just a way to copy from box to pc and visa versa
                Derek
                • roblowe91
                  #23
                  cheers derek, it's becoming slightly clearer
                  • Derekwd
                    • 244
                    #24
                    Get yourself a ftp prog, flashfxp seems a popular one
                    Derek
                    • roblowe91
                      #25
                      got that ftp program,but as it turns out, i didn't require it. managed to get new codes and did it ll from my remote..RESULT. but thanks for the advce
                      • mickydibble
                        • 2166
                        #26
                        its ok to manually input codes but you will soon get fed up of updating that way,when you have to get new keys ,best to learn how to ftp the au roms,and get your head round the box or you`ll be back very quickly....always best havin a near permanant fix....all the info needed is on here...big up digital-kaos....micky
                        • PaphosAL
                          Old Git
                          • 1064
                          #27
                          Jeez! There was a Sunday 'big' footy match a few weeks ago (weekend following the hit) where they rolled the keys 10 mins before kick-off, again during half-time, and then their finishing touch: a simultaneous double roll at around 6pm!
                          Yes- on a Sunday. So carry on with your manual key entry by all means, m8. Just be aware that while you're waiting for the 'new' info to appear- it might be out of date already!!
                          Get yourself set up with a proper AU image. It's not Brain Surgery...
                          Cheers- AL
                          • idekuk
                            • 15
                            #28
                            Try the new Lincsat 7.25 fullish Image and ftp your local services and bouquet files. should fix the freezing and other probs good luck.
