Eurovox PVR EX5100 Channels
  • hoopy09
    • 20
    Hi guys just got the box done a deep scan, all the channels are there, but when i put it on sky sports 1 it says Scrambled channel.
    Any help would be much appreciated guys cheers.
  • camelv
    • 1202
    not sure about this box but think you might need to do a factory reset first
    its the stuff we think we know that stops us all from learning
    • hoopy09
      • 20
      How do i do that mate. am quite new to these kind of boxes.
      • camelv
        • 1202
        as i said i havnt had one of these although i do have a couple of e/vox boxes ,it should be the same .
        go to menu
        go to config
        go to clear data
        enter pin
        select factory reset
        delete all channels will come up press ok then do a power scan.
        check this link first m8
        • hoopy09
          • 20
          go to menu
          go to config
          go to clear data
          enter pin
          http://www.digital-kaos.co.uk/forums...settings-9789/
          Done that mate still no change.
          • Lanxman
            • 552
            Hoopy, Have you flashed the box with the correct firmware before scanning?
            Sometimes a slow gradual approach does more good than a large gesture.
            • hoopy09
              • 20
              Not done that mate, thought it would have been flashed when i got it . quite new to this.
              Is there anyway i could flas it without the Serial Null Modem Cable as i dont have one?
              • Lanxman
                • 552
                No sorry mate you have to use a null modem cable for that box, Can't be done via usb. Also, If you have a fairly new desktop/laptop you will need a null modem cable to usb adapter as well as a null modem cable. Boxes no longer come pre flashed.
                • hoopy09
                  • 20
                  Yeah i have the null cable, but my pc is quite new, dont have null modem cable to usb adapter.
                  So i will need to buy one of those? to get it working.
                  • Lanxman
                    • 552
                    Yes, unless you know someone who has a really old pc or if you have an old one lying about. Failing that you will have to buy one, You can get them from maplin's but they're about ?20 from there, you should be able to pick one up cheap on flea bay
                    • camelv
                      • 1202
                      sorry m8 thought you had already flashed box ,
                      • hoopy09
                        • 20
                        cheers guys will need to get one 2moro.
                        • Lanxman
                          • 552
                          No worries mate, If you have any issues with flashing when you get it have a look round the forums there's loads of help in this topic.
                          • Paul R
                            • 19
                            i have exectly the same problem with nick jnr 2
                            which my little lad loves , av got all the latest firmware and it still says scrambled channel
                            • HiTeck
                              • Oct 2008
                              • 996
                              On the nick jnr 2 channel press info twice, take a note of the freqs it will show at the top left hand side.
                              Now go to Menu, Installation, press OK on User Installation, Enter pin 0000, Highlight the Freqs you noted before by pulling down on your remote then press OK so a tick appears at the side then press manual scan which is the "blue button". Leave it to scan usually takes around 30 seconds then exit back to nick jnr 2 and now the channel should be working..
