Eurovox EX1000 Signal problem
  • Caz64
    • Mar 2009
    • 5
    Hi - I purchased the EX1000 last week and almost ended up throwing it out of the window. It kept coming up with "bad or no signal" then when we got a picture it would break up. Signal strength was coming in at over 83 - tried different attenuators without much success and now trying a variable attenuator which seems to be doing the trick. Signal is ranging from 78 - 81 and picture seems to be staying stable on most channels at the moment. However, I do have a problem with everything that comes in on frequency 730 - eg Sky Sports 1 & 3. These channels have a signal of 77% and are all over the place. Sky Sports 2 working perfectly at 80% Tried manually adjusting frequency but hasn't made one bit of difference. Is there anything else I can try to get these channels coming through better?
  • wasi786
    • 71
    hi
    what area do you live in - this is starting to happen to a number of EuroVoxes - this is also happening to me
    the signal strength from virgin has become too strong it keeps fluctuating - they are doing this due to the 50mb broadband rollout - theres nothing you can do till the signal is stable
    would just say keep adjusting the attenuator till this is resolved
    • satsmo
      • 6397
      There is new firmware, (dated 24/02/09), released for both the EX1000 and EX5000, that is supposed to remedy the signal problem.
      You will find it on the usual toolbars. I have not put either in downloads yet, (as they have come from somewhere other than usual), and as I haven't tried it on my own boxes as of yet but will do now. I wouldnt like to see others with dead boxes, well at least I will be the only one with dead boxes to put it another way But elsewhere people have said they are fine.
      If they are OK I will up them.
      • Caz64
        • Mar 2009
        • 5
        Originally posted by wasi786
        hi
        Hi - Thanks for the info. I live in North Manchester area so would be interested to hear if others in the area are having the same problem.
        • Caz64
          • Mar 2009
          • 5
          Thanks for the info. I hope the new firmware does remedy the signal problem!
          • Gericom
            • Mar 2009
            Is there anything for the max v, encountering the same problems
            • satsmo
              • 6397
              For a signal problem on a Max V try this firmware
              • satsmo
                • 6397
                I have updated the firmware links here http://www.digital-kaos.co.uk/forums...firmware-9787/ there are two revisions for the EX1000. One with auto sort enabled and one without.
                Both have the booster option now in config, so may be worth a try.
                • wright1forme
                  • Jun 2009
                  ex1000sl problem with freezing, jumping picture and crackling can anybody help up to date firmware
                  • badapple
                    • 2041
                    Hi m8, sounds like a signal proble but here the latest sofrwa*e for your box>Digital Kaos - Downloads - UFL_EX1000SL_24-02-09_DarX
                    SLOWLY, OUR FREEDOM IS BEING ERASED.
                    SOON, WE WILL JUST BE A NUMBER.
                    IF WE DON'T FOLLOW, WE WILL BE ERASED.
                    • ucsm
                      get this
                      variable attenuator mate.
                      • GJP10
                        • Aug 2009
                        • 10
                        Hi There - I scanned my box with the latest firmware two weeks ago - The picture had been working good - I got home from work yesterday and all the channels were saying no or bad signal - I also have a variable attenteur - I have re-scanned the box several times and it's only installing about half the channels and the picture is horrible - The quality strength says about 79% - Can anybody help me!!
                        • toontoon1234
                          • Sep 2009
                          • 36
                          hi there, u manage to get it sorted?i cld do wih sum help here,am unable to get subbtitles on mine,wen i press text i select sub but then nothing happens,wot ya reckon?
                          • jaydagreek
                            • Sep 2009
                            • 13
                            hi i ve recently purchased a eurovox ex 1000 sl set it all up and did not even get a menu on start up ? just a blank screen have tried changing scart cables etc hav downloaded and installed firmware still no luck its doing my nut any 1 help ?? oh im running it on virgin through a splitter thanks
                            • Drefsab
                              • Mar 2009
                              • 26
                              you should at least get the menu, if you cant get that far you may have a dodgy box. As for the Manchester issue no fix for it atm so if you live in the Manchester area you may not get any channels even with a working box.
