need help EX1000SL
  • gtgolf
    • Oct 2008
    • 20
    need help EX1000SL
    hi
    try to put firmware in my ex10000sl box got firmware downloaded
    and when I press on download inbox I keep getting NO COM PORT FOUND
    but they are working ok. I have been into device manager and seem to ok
    THANKS
    gtgolf
  • delboy13
    • 415
    have you tried pressing download then plugging in euro to mains
    • gtgolf
      • Oct 2008
      • 20
      hi
      thanks I HAVE JUST TRIED THAT, STILL DIDN`T WORK
      • BROKENSTONE
        • Oct 2008
        eurovox ex1000
        how do i download the firmware for this box please?
        • BROKENSTONE
          • Oct 2008
          eurovox 1000sl
          how do i download firmware for this box please?
          • deano1981
            • 66
            hi you can download the bigmaq toolbar then select eurovox ex1000 under files and fixes tab from, the darx file is the one you want hope this helps
            • deano1981
              • 66
              sorry you can also get it from the red download tab at the top this page
              • skytrax18
                • Oct 2008
                please can someone send me the link for the guide to detail how to connect the eurovox ex1000sl to my pc via rs232 cable, im kinda stuck on what to do can someone help me out would appreciate the help, thanks!
                • thered
                  • Aug 2008
                  • 4915
                  you need to connect your pc to your box via the rs32 null modem cable download the firmware for your box(its here in the d/load section)
                  open it then d/load to your box this is called flashing
                  then you just need to scan for channels set your area symbolrate first either 6.887 or 6.952 scan leave on sky sports 1 to update code then your away
                  • pv1
                    • 5
                    Eurovox EX5000 PVR
                    hi was wondering if som1 could help me i have n pay minimum subs for virgin and have just purchased a Eurovox EX5000 PVR im a newbie dont no how to set it up to recive all the virgin channels on the Eurovox EX5000 pvr.
                    could som1 tell me what firmwares i need to istall and wat configurations i need to make to the actuall box
                    • reddave
                      • Oct 2008
                      • 122
                      read the red sections at top of forum download firmware for your box,connect box to computer using null modem cable then flash box, then just scan for channels leave on sports 1 to update should take no longer than 10-15 minutes
                      Justice for one.........96 left
                      • TaxiDave
                        i am having problems with my Eurovox Ex1000sl dont know how to load a firmwire on to it i have been looking over the internet for a whiule now can anyone help!
                        • HiTeck
                          • Oct 2008
                          • 996
                          Hi TaxiDave, have a read through these mate, any problems come back. all the info you need is in there.
                          • uktv
                            • Mar 2009
                            ex1000sl
                            Am in the same position as some of you good people with regards to this box. I get "the receiver was not detected" - any advice much appreciated.
                            • satsmo
                              • 6397
                              Take a look at HiTeck's post directly above your post. Take particular note of the cables required link.
