eurovox pvr ex5000
  • kevmay36
    • Oct 2008
    • 4
    eurovox pvr ex5000
    Hi guys bit of a newbie to the site hope you can help me
    have got eurovox pvr ex5000 have got all the channels thats no problem but
    have a constant problem with box freezing and coming up sayin scrambled channel i had a eurovox max 2008 box before and this found the code after about 30 sec no problem this new box is causing me a load of hassle have flashed the firmware to the latest but has not fixed the problem
    thanks in advance kkk..
  • thered
    • Aug 2008
    • 4915
    are you using this one
    Digital Kaos - Downloads - new eurovox pvr software release v1.1A
    • kevmay36
      • Oct 2008
      • 4
      yes thats the one im using i catually downloaded it from the chatterbox files& fixes section of the toolbar
      just some more info that may be relevant i have split the signal to three boxes two
      pvr ex5000 and one original VM box but the quality has not dropped has this anything to do with it , freezing/scrambled channels happens on both boxes
      • thered
        • Aug 2008
        • 4915
        thats probably why then m8 you will need a booster then everything should be sound
        • kevmay36
          • Oct 2008
          • 4
          ok m8 what sort of booster do ineed and where can i get one from thanks.
          • thered
            • Aug 2008
            • 4915
            just have a pop to argos no quibble money back if it doesnt work or a lot of people recomend the konig yellow brick
            Konig Cable TV/Broadband Signal Amplifier Booster NTL on eBay, also, Cable Boxes, Satellite Cable Freeview, Consumer Electronics (end time 18-Oct-08 16:32:21 BST)
            • kevmay36
              • Oct 2008
              • 4
              cheers mate will get one and try it thanks again ...
              • deaksey
                • Apr 2009
                • 7
                thanks alot great link
