This is to explain in simple terms how the n3 system works.
***Taken from another site, so thanks to guy who wrote it.***
All encryption is based on a mathematical formula?. For example? you start off with a code to crack and the idea is that you want to find out how many apples Johnny has in his bucket?.. here is how the systems would work?
NAGRA 1?.. this works on basic addition (not really.. this is the part where I am makin? it simpler)?. You start off with someone leaking that there was originally 3 apples in Johnny?s bucket?. The only mathematical process Nagra 1 knows is addition?.. so? the provider sends down the number 5 in the data stream? through basic addition your formula tells you to add 5 apples to the original 3? you get eight and boom?.. you know the answer?. A simple calculation like this would be done millions and millions of times by your receiver in seconds?.. this produces your tv pic using binary language?. When the provider uses addition to change the amount of apples originally in the basket you need a new bin file to help your receiver decrypt the signal?.
NAGRA 2?? Now you introduce subtraction into the mix? now the provider can change the number of apples originally in the basket both ways? add more or take some away?.. the equation is twice as complicated and your receiver has to work double time?? every once in a while the equation gives you a previous number used because due to subtraction you can go back to a previous number?. This is what happens that causes a previous bin file to work?..
NAGRA 3? Ok? let?s say this bad boy can do multiplication?.. now your equations are 3 times as difficult? it is harder for coders to find the formula?. Your number of original apples can now go from 100000 to 2 in a flash of a second due to multiplication?? your receiver is working triple time?? it takes the coders longer to learn how many apples are in the basket??
Bottom line? the bad news is that you may not have any apples in your basket for a while since the coders will need time to figure this out??. The good news is that they are geniuses and a whole lot of rich folks will be losing a pile of money until they get some apples back in your basket???.. no worries?.. we will get some downtime but we will be back up and running?.
i also hate apples,nasty little ~~~~ers
