Zgemma Star H2 - VM Setting not working
  • Ozzo76
    • Mar 2016
    Hi Folks,
    I have a Zgemma Star H2 i'm trying to set it up for VM, I think i'm putting in the correct settings but if i'm not hopefully someone can advise me, so the settings I am using are :
    Select tuner B by pressing okay and make sure config mode says enabled>>>In network ID enter (this is my area - Belfast (Ireland) NTL 00021 755.000 6.887 can someone tell me my NetID ?)
    Cable netids
    Used Service Scan = Provider
    Provider to scan = Virgin Media (6952) <<<---- do I still use this or do I change this to from my area line above?
    Press green to save then red to close then red to close again
    Go to auto bouquets maker then providers make sure Kabel = no>>> virgin uk = yes>>>virgin uk area = Net I.D select by going left or right arrow
    once I've done all this when I select automatic scan I get this "Timeout for tuner lock" can anyone help me out?
    many thanks
    Ozzo
  • martin035
    • Apr 2014
    • 1308
    The Zgemma H2 is a Sat/Cable box so if you don't need the satellite side of things you need to disable Tuner A hopefully that should stop 'Timeout for tuner lock' error, if you do have a satellite feed into tuner A then ensure you set up Tuner A for 28e and Autobouquetsmaker for your satellite UK/ROI region aswell.
