DreamUp problems
    Other people connect via usb no probs m8, I've never succeeded. Pot luck mkaybe. Try a different OS or a different pc without a usb
    • cloudnineuk54
      • 530
      #17
      ive used dreamup on vista with no problems,but although i installed the drivers that came on a cd with my usb adapter,before i used it i done a widows/software update,which did find updates for it,just a thought you could try,i also used a dbox proggy to send image to box and flashed using remote,i found this to be so easy,maybe you could try it. good luck 4shared.com - online file sharing and storage - download image2box.zip i used ordinary ethernet from router to box,the image i used was neutrino so i made sure i named image mtd.img so proggy found it ok,same if you use enigma name that right so proggy finds it ok,but im not sure on that youll have to ask
