DreamUp problems
  • owen7
    • Aug 2009
    • 78
    DreamUp problems
    Hi guys,
    Right here goes! I've just bought a OpenMedia box and today i've just recieved my cables in order to flash it using DreamUp.
    Problem i'm having is i can't get any further after connecting the Null modem lead i then plug in the box, power on then wait... but nothing happens, i am using the Guide: Flashing a Dreambox with Dreamup
    I am using a USB 2.0 TO RS232 SERIAL DB9 9 PIN ADAPTER CABLE then a Null modem cable connected to that due to my laptop not having a solo R232 output, would that matter?
    Any help much appreciated
  • hipparcos
    • Aug 2009
    Originally posted by owen7
    Hi guys,
    Hi mate,
    Having tried this kind of setup with numerous settings myself and failed miserably, i used a pc card for the laptop with a proper 232 interface. This finally worked.
    Sad but true.
    Cheers,
    Frank
    • cloudnineuk54
      • 530
      ive just flashed mine using same cables as yourself no problems at all,are you sure your drivers are installed for the adapter,and also are your com ports are set correctly
      • simonn
        • Aug 2009
        • 54
        I dont have this box I have a eurovox.
        However when i plug in my box using the null modem I don't get a response from it either. However if I just use the firmware update or whatever I need to do, it works on it but still doesn't respond if you see what I mean?
        • owen7
          • Aug 2009
          • 78
          Originally posted by hipparcos
          Hi mate,
          Sad but true.
          Cheers,
          Frank
          Hi there bud,
          Not what i wanted to hear! just bought the usb to serial cable & a null modem cable after doing some research before hand aswell!
          Ta anyway.
          Hi mate, this is what i want to hear! i'm guessing the drivers are installed as usb to serial came with a drivers cd which i've ran & installed - the other cable, the null modem lead didnt come with any cd - i'm guessing it doesnt need drivers.
          I can get the connection prepered screen ok after pressing connect in DreamUp but when i then plug the OpenMedia box to power on i then get nothing - no blue progress bar appearing within a second or two like it should, i feel like
          Here's me thinking it would be dead simple grrrrrrrrrrrrrr
          • owen7
            • Aug 2009
            • 78
            Anyone any ideas? got an expensive door stop @ the mo!
            • opsmonkey
              • 5379
              are you running Windows Vista..??
              this has had issues with the USB adapter..
              • EAMO 2
                • 1201
                If you have ethernet crossover cable you could FTP image to your box
                using FXP or similiar program. Have found some USB-9pin cables will
                work fine flashing cable-tuner boxes, but will not with Dream-Up.
                • EAMO 2
                  • 1201
                  Get your hands on P.C. with 9pin com-port, set to COM 1,2,3,or4.
                  Eurovox loader will only detect COMS 1 2 3 or 4, so make sure of com-port
                  settings. This could also be your problem using USB-9pin. So have a look.
                  • owen7
                    • Aug 2009
                    • 78
                    Hi, nope i'm running XP.
                    Thanks for that, i've read somewhere in the many guides i've looked at! that i can use a normal ethernet cable (not crossover) if you do it via a router is that
                    right?
                    I will buy a crossover cable if need be though, seen them for about ?1.50 on ebay.
                    Cheers.
                    • EAMO 2
                      • 1201
                      right?
                      Cheers.
                      Correct, via router straight ethernet is suitable
                      • owen7
                        • Aug 2009
                        • 78
                        ****kin get in there! i've finally managed to flash a image onto my box <-------------- that's how i feel right now!
                        just like to say thanks to this site and all the helpful guys on it, as without you it wouldnt have been possible
                        I've just the small problem now of no channels appearing when i do a search !
                        • mdeee
                          • Sep 2009
                          HI
                          I have this same poblem as Owen7, how exactly did you get it sorted using router via ethernet??
                          • mdeee
                            • Sep 2009
                            Help?
                            How does this method work ,please give some guidance??
                            • zzzakos
                              Help please
                              I have Windows Vista and I cant connect to DreamUP with USB-RS232 cable.
                              This is the only way I can use sailer.
