Other people connect via usb no probs m8, I've never succeeded. Pot luck mkaybe. Try a different OS or a different pc without a usb
DreamUp problems
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
ive used dreamup on vista with no problems,but although i installed the drivers that came on a cd with my usb adapter,before i used it i done a widows/software update,which did find updates for it,just a thought you could try,i also used a dbox proggy to send image to box and flashed using remote,i found this to be so easy,maybe you could try it. good luck 4shared.com - online file sharing and storage - download image2box.zip i used ordinary ethernet from router to box,the image i used was neutrino so i made sure i named image mtd.img so proggy found it ok,same if you use enigma name that right so proggy finds it ok,but im not sure on that youll have to askLast edited by cloudnineuk54; 30 December, 2009, 00:48.Comment
